LetterX
I have a Pro-95 that I need an interface cable for, but I'm not keen on spending $30 from GRE or $35 from Radio Shack. From what I've read, these cables are USB to Serial to TTL adapters. Can I use a cheap $5 USB to TTL adapter off eBay, and just wire it up to a 1/8" plug? If so, should I set the TTL adapter to 3.3V or 5V (apparently there's a jumper). I'm talking about a TTL adapter like this one on eBay, and hook it up like this:
Will that work?
Will that work?
