This might be more of an antenna question, rather than a scanner question, but maybe someone can shed some light on this...Can anyone make a tried and true recommendation for an antenna for a Radio Shack Pro-96 monitoring the 865-868Mhz APCO-25 band? I upgraded to the "Deluxe" Radio Shack rubber-duckie (20-034) which sounds noticeably better than the stock antenna, but I still get a lot of digital garble. I will say that the 20-034 seems to also perform better than the Radio Shack Center-Loaded Telescoping Whip (20-006) on this band. I'm thinking about getting the outdoor (20-176) antenna but heard from several people that it doesn't help with receiving APCO 25. I'm even thinking about experimenting with a homemade 50 ft speaker wire antenna. Please note that since I primarily use my scanner indoors, I installed a mount outside the window for better antenna reception with a BNC tipped cable going inside the house.
