Hey all,
I just got a new RS Pro-106 and I am having the hardest time setting up this system. I am fairly new at this. The preprogrammed data for this system (Gainesville/Alachua County) is all wrong and will not scan. Someone please help me program this; im all confused (the rebanding does it make it any easier):
Gainesville / Alachua County Trunking System, Gainesville, Florida - Scanner Frequencies
or
System Name: Gainesville / Alachua County
County: Alachua
System Type: Motorola Type II SmartZone
System Voice: Analog and APCO-25 Common Air Interface
Last Updated: January 26, 2011, 8:05 pm (Updated Talkgroups (1 Updated))
Collaborate
For more information about this trunked system please see this entity's Wiki page:
•Gainesville / Alachua County Wiki Page
To discuss information online about please see these forums(s) in the RadioReference.com Forums:
•Florida Radio Discussion Forum
Important Rebanded Note
One or more sites for this trunking system have gone through the 800 MHz rebanding process. Your scanner may be incompatible, require a firmware update or require special programming to track these sites. Please visit the RR Wiki Rebanding page for additional information.
System ID List
System ID Connect Tone
7B2D 138.46
Misc System Information
All of Alachua County and the City of Gainesville Public Safety has moved to this ASTRO Smartzone system. Most if not all communications on this system are in APCO-25 Digital mode. The system is actually run by the Gainesville Regional Utilities (GRU).
To be able to monitor this rebanded system with Uniden scanners (996T, 396T, 396XT, etc), you MUST use a custom Band Plan. The default settings recommended by Uniden work: program in the control channels, then edit the band plans by setting Band Plan 1 and Band Plan 2 to this (BOTH band plans MUST be entered): Band Plan 1: - Base (lower) = 851.025 - Base (upper) = 854.000 - Offset = 440 - Polarity = + - Spacing = 25-KHz Band Plan 2: - Base (lower) = 851.0125 - Base (upper) = 868.9875 - Offset = 0 - Polarity = + - Spacing = 25-KHz Without these settings, the scanner will not go to the correct voice channels, especially when the control channel itself is on a splinter frequency (like 853.775).
System Frequencies
Red (c) are primary control channels | Blue (a) are alternate control channels | Site Map(s): FCC Callsigns RR Locations
Site Hex Name Freqs
001 1 Simulcast 851.08750 851.13750 851.18750 851.41250 851.63750 851.66250 851.77500 851.91250
852.05000 852.18750 852.27500 852.30000 852.41250 852.56250 852.68750 852.77500
852.81250 853.06250 853.11250 853.18750 853.31250 853.36250 853.52500 853.56250a
853.67500a 853.77500a 853.81250c 853.86250
or
County: Alachua
Collaborate
System ID List
7B2D 138.46
System Frequencies
Site Hex Name Freqs
