Old 05-16-2011, 5:08 PM
Default Firmware (CPU 1.9) for Pro-106/197
There is new firmware (CPU 1.9) out for the Pro-106/197.
Here is a link:
PRO-106 39,000-Channel Digital Handheld Scanner - RadioShack.com
Old 05-16-2011, 5:14 PM
Here is a link:
Good find, Dan!
...but a real YAWNER of an update from Radio Shack:
"Pressing the ATT key during scanning while on a CONV object causes the object to
be stored to EEPROM immediately. This eliminates the possibility of the ATT status
change being lost due to a Priority check."
Apparently that's all there is to this firmware upgrade. I'll pass...
broonzbane
Old 05-16-2011, 5:18 PM
RIG RIG is offline
Thank you for the notification of this.
Rob
Pro-197 and Pro-106 with ARC 500 software
Old 05-16-2011, 5:22 PM
RIG RIG is offline
Originally Posted by broonzbane View Post
Good find, Dan!
broonzbane
This isn't an earthshaking update but why not have you radio as current as possible? If someone skips some updates, can you install something later on after not installing this one? I would think they all need to be entered as they are released.
Rob
Old 05-16-2011, 5:41 PM
Rob
I just don't want to risk bricking my radio in the firmware upgrade for ONE feature that I will never use. There needs to be a LOT more meat on the bone to entice me to upgrade the firmware, otherwise it's useless to me.
But, that's just me. I can certainly understand it when people want to keep their equipment as current as possible...
BTW, when you do a firmware upgrade, all code written to the EEPROM is deleted and replaced. So, there's no need to worry about making sure you're getting everything in the right sequential order...
broonzbane
Old 05-16-2011, 7:00 PM
RickS31's Avatar
Yeah, if this all that this does, not worth updating. There is more that they could've done than this. I will look into it further to see if that's all. If so, I hope next one adds to functionality, otherwise I'll just sit on it's current functionality.
Rick
2 - PRO 106, PRO 23 - Win500
Old 05-16-2011, 7:45 PM
Kel's Avatar
Kel Kel is offline
I wonder why GRE didn't release it first on there units?
Old 05-16-2011, 8:02 PM
mikey60's Avatar
broonzbane
The risk of "bricking" your radio is extremely remote, if not impossible. From what I've seen the boot loader is pretty solid in all of the GRE radios that have upgradable firmware. Even if the upgrade fails, all you need to do is try it again and the radio will be fine.
http://www.psredit.com
Old 05-16-2011, 8:04 PM
mikey60's Avatar
Rob
Not a problem to skip an update. When upgrading firmware you completely replace the firmware that was in the scanner previously with the new firmware. You can go directly from a 1.1 to a 1.9 without any issues.
Old 05-17-2011, 9:06 AM
RIG RIG is offline
I did the upgrade to both of my radios as it only takes 2 minutes to do each one. The instructions specify it cannot do any harm to the radio. I saw no downside to adding it.
Rob
Old 05-17-2011, 11:53 AM
w2txb's Avatar
Lightbulb
Just "upgraded" mine as well; not a big deal either way, but at least RS is sending out updates to tell us they have not forgotten us.
"Non Impediti Ratione Cogitationis"
Old 05-17-2011, 7:16 PM
zzdiesel's Avatar
I can't update mine. The program doesn't recognize my radio on Com 1. Win500 works just fine though. It may be that I am running Win 8.
Whistler - TRX-1 /w EZ-Scan
Old 05-17-2011, 7:44 PM
RIG RIG is offline
I know when you start the download it says com1 but your computer like mine is most likely above there. Mine was com10. Doesn't your device manager show what it should be?
Rob
Old 05-17-2011, 7:52 PM
zzdiesel's Avatar
Device Manager says it is Com 1
Old 05-17-2011, 8:03 PM
RIG RIG is offline
That's strange. Have you tried to uploaded anything to see if it would accept a new frequency?
Rob
Old 05-17-2011, 8:14 PM
zzdiesel's Avatar
Yes, Win500 works perfectly; both downloading & uploading.
Old 05-17-2011, 8:52 PM
Try com3 com4 or com5 my win500 does not tell me which com it is using, but my arc 500Pro tells me it is com 4. Just try different com in the download area and follow the instructions.
BCD396T, BC-RH96, PRO-106, and AOR AR8000
Software: Win-500, Arc500-Pro, and UASD
Old 05-17-2011, 8:57 PM
zzdiesel's Avatar
I tried your suggestion and still no go. I'm going to try Windows in a bit and see how it does.
Old 05-17-2011, 11:55 PM
I had the same problem but then I removed the extender from my cable and it worked fine. I have the older one with the orange box in the middle.
Old 05-18-2011, 12:12 AM
zzdiesel's Avatar
Thank you. I'll try it tomorrow or Thurs. Are you talking abouty the mono extender? I don't have it hooked up. I also tried it in Windows 7 and it did the same thing.
