Old 06-07-2011, 11:44 PM
Default pro 164 in clone mode
need help screen says Clone Mode, Press UP to send, remove cable to exit how do I fix this
Old 06-08-2011, 12:07 AM
You have either
1. A cable plugged into the pc/if jack on the scanner. Remove the cable.
Or...
2. A physical hardware failure of some kind inside the scanner. Inspect the jack to be sure something isn't stuck in there. You may need to take it apart to inspect.
Old 06-08-2011, 4:50 PM
KC2GVX's Avatar
Scroll down a few pages... I had this same problem about a month ago. Fellow posters had really good advice, and I tried them all. Sadly, none worked for me, so I sold mine on eBay for about half of what it was worth. Good luck though!
President, Founder & CEO of Ocean County Scanner News!
