Old 06-14-2011, 12:23 AM
Default Channels Locked Out
On my Radio Shack Pro 96 Digatal Scanner I accidently touched some buttons and got the message "All Channels Locked Out" How do I unlock my scanner channels ?
Old 06-14-2011, 1:10 AM
InlandAZ's Avatar
That happens when there are no frequencies programmed. You must have cleared the scanner.
Old 06-15-2011, 11:59 AM
The bank(s) you are scanning have no frequencies programed in them. Look at the top of the display, there should be "dots" or numbers "0 to 9". When a number is displayed, that bank is selected for scanning. Select the banks by pressing the number on the keypad for thay bank. Each time you press a number key, the bank will be turned on or off.
Doug
Pro2B/40/43/77/83/84/89/96/97(2)/99/106/107/137/164(2)/2026
BC235 BC245 SC230 ICR3, ICR10
+ HF, VHF & UHF Xceivers from Alinco Icom Kenwood Yaesu Vertex Maxon Mot & RS
Old 06-16-2011, 5:54 AM
Default Pro-96:Channels locked out
Check to see if there are any frequencies programmed by pressing the manual button and a channel number (example 001) where you programmed a frequency. If see the frequency displayed reads 000.000 mhz instead of a frequency (example 162.550 mhz) you may have erased all your frequencies. If however
you see frequencies displayed then you may have locked a scanner bank or all banks you have channels
programmed. For instance if you have all your frequencies programmed into bank zero (channels 000 to
channel 049) you should see bank 0 on the list of numbers 0 through 9 on the top line of the display.
To turn on a locked out scanner bank for example bank zero, push scan and then push the 0 button to enable
that scan bank.
