Old 06-18-2011, 2:09 PM
Default singal stalker
i hit the wrong button and now it keeps showing singal stalker how do i turn this off
Old 06-18-2011, 2:38 PM
OsloViking1975's Avatar
press FUNC SCAN to get to Signal Stalker mode, and then press SCAN again to go back to scanning, rather than creating a stalker object
Baker College Major:Criminal Justice
Monitoring Macomb,St.Clair, Wayne, and G.P.I.S.
"Dedication lies in the hands of those who are dedicated". 9-1-1 Certified hours completed.
Old 06-18-2011, 3:44 PM
Default stalker
ok hit fun scan and then scan again ,when its scanning at the bottom it shows signal stalker at the bottom
Old 06-19-2011, 11:09 PM
N1BHH's Avatar
It would help to know which scanner model that you are asking about.
WQWJ272 = GMRS
Pro's 94, 106 x2, 164, 197 x2 , 2006, 2015, 2021, 2055
Old 06-20-2011, 2:58 AM
It looks like he has the PRO 106 from reading some of his other posts.
Old 06-20-2011, 3:03 AM
Signal Stalker II
Signal Stalker II allows you to watch for activity on all band frequencies or Police/Fire frequencies only. You can also turn on/off frequency sub-bands using the corresponding number keys.
Signal Stalker II will not work in the background like Signal Stalker I or Close Call.
Once an active frequency is found, the transmission is played through your scanner’s speaker, and you can quickly store it in any of your scanner’s memory locations.
Signal Stalker II functions by rapidly sweeping through the RF spectrum in 1 MHz segments. If RF signal energy is detected in a 1 MHz segment, Signal Stalker II will sweep through the 1 MHz segment in finer steps until the source of the RF signal energy is found.
You can change the normal Signal Stalker II operation to the Special Signal Stalker II operation. If you lock out 5 frequencies within a 1 MHz segment, the scanner will skip that segment in subsequent sweeps.
Old 06-20-2011, 3:09 AM
From the Easy to Read PRO 106
To start a dedicated Sweeper/Stalker Search press FUNC then SCAN.
To switch between All bands or just Public Safety Bands.
Press F1 (Band).
(Press FUNC then F1 during transmissions to override FrL/O).
To toggle bands on or off press the number key assigned to the band.
To turn 'Special Stalker/Sweeper on or off press F2 (spcl). SPCL (uppercase) indicates 'Special' is active.
To change direction or resume searching press
or .
To pause on a frequency
press PSE.
To lockout a frequency press F1 (FrL/O).
To unlock a frequency see Unlocking Search Frequencies.
To toggle the receive modepress F2 (Mode).
To store a frequency into the Default Scan List press F3 (Stor).
To toggle the search delay on or off press FUNC then . (DELAY).
To toggle attenuation for the search on or off press ATT.
To toggle zeromatic tuning on or off press FUNC then 0.
To exit press SCAN.
Notes:
See also BandPlan and FlexStep settings (in the 'Expert Settings' menu) for step size defaults.
Priority mode is not available while using Signal Stalker/Spectrum Sweeper.
