royalzapper
Hamilton County TRS (APCO-P25 9600 baud)
System Type: Project 25 Standard
System Voice: APCO-25 Common Air Interface Exclusive
The Digital Scanner Team located in Hamilton County, Ohio.
Has observed a problem with some Radio Shack PRO-96 &
PRO-2096 Radios.
That I first called "Closed Mode MOT: bleed over".
When the Banks are set up in the "Closed Mode".
The problem is receiving transmissions of talkgoups that
haven't been programmed in the Radio's ID list.
The Radio will display the MOT: ID #.
Also if you lockout this MOT: ID # that was displayed, the
Radio will lockout a different talkgroup that is stored in the
Radio's ID list.
Example # 1:
Bank 01 is set up in the “Closed Mode” to only receive the
transmissions of the Hamilton County Police.
Talkgroup # 00051 is programed in the Radio's ID list with the
alpha tag of LE EAST DISP.
When you receive Hamilton County East Dispatch transmission
the Radio will Display the associated alpha tag LE EAST DISP.
Then you receive the transmission of Cincinnati Police Dist. 2
This talkgroup is HAS NOT BEEN programed in the Radio's ID list!
MOT: 32819 will show on the Radios display & you hear the transmission.
If you press L/OUT the Radio will lock out # 00051 alpha tag LE EAST DISP.
The revise action will occur in Bank 04 that is set up in “Closed Mode”
for Cincinnati Police. MOT: 00051 will show on the Radios display and
you hear the transmission. If you press L/OUT the Radio will lock out
talkgroup 32819 DIST 2 Disp.
Example # 2:
Bank 01 is set up in the “Closed Mode” to only receive the transmissions of the
You have programed in # 00081 & the alpha tag AW 19
When you receive a encrypted transmission.
MOT: 32849 will show on the Radios display {This is Cincinnati PD C2C 1}
If you press L/OUT the Radio will lock out # 00081 & the alpha tag AW 19
Consistently the same talkgroup ID will be locked out when the Radio
receive the transmission the opposing talkgroup!
What we have discovered is within the Talkgroup ID 16 bit TGID field.
That some Radio Shack PRO-96 & PRO -2096 Radios are neglecting
the high bit. When the Radios are receiving transmissions of talkgoups
there could be a translation table error at bit 0x8000 within the 16 bit TGID field.
The Hamilton County / Cincinnati TRS system has 105 talkgroups
that with the exception of bit 0x8000, that are "IDENTICAL".
Here is a example of 10 talkgroups:
TGID
Digital 16 bit field Alpha Tag
00001 0000 0000 0000 0001 FD DISP 1
32769 1000 0000 0000 0001 MAIN AUX
00051 0000 0000 0011 0011 LE EAST DISP
32819 1000 0000 0011 0011 C PD DIST 2
00052 0000 0000 0011 0100 LE WEST DISP
32820 1000 0000 0011 0100 C PD DIST 3
00053 0000 0000 0011 0101 LE CENT DISP
32821 1000 0000 0011 0101 C PD DIST 4
00054 0000 0000 0011 0110 LE SPARE
32822 1000 0000 0011 0110 C PD DIST 5
00395 0000 0001 1000 1011 JAIL 3
33163 1000 0001 1000 1011 SPARE 11
All Radio Shack PRO-96 & PRO -2096 Scanners here in Hamilton County, Ohio
are not effected which leads us believe that the problem is not in the firmware.
We have confirmed this problem with CPU: 1.1 , 1.3 & 1.4
Our goal is to bring this problem to the attention of GRE & Radio Shack.
We would like to know with this information is there a way that you can
bench test the binary logic translation table and detect the error at
royalzapper
Billy Zapf
PRO-2096 Radios.
Radio's ID list.
Example # 1:
Example # 2:
TGID
royalzapper
Billy Zapf
