- Joined
- Jul 7, 2010
- Messages
- 588
I am hoping that somebody can help me with this issue I am having... I'm trunking a Motorola Type 2 SmartZone system and for some reason in the middle of transmissions the audio cuts out for a second or 2 and comes back on, causing me to miss an entire address or half a Driver License #, just an example. It's rather annoying especially since I dispatch calls for IPN and it requires listening to calls live and I can't hear an address or get a partial arrival report because the scanner cuts in and out. I have programmed it correctly, I don't have PRI or WX activated, I've turned ATT on and off as well as Global ATT on and off, I've tried erasing the memory and re-programming it all over, I just can't get this issue fixed and it's driving me bonkers. And it's not the area I'm in because I'm in the middle of a metropolitan area with no shortage of radio towers. If you listen to my live scanner feed link here long enough you will see (hear) what I am talking about in regards to listening to something and the audio cutting off for a second while someone is talking. If anyone has any suggestions (besides buying a new, better scanner LOL) please let me know... Thanks!
