Old 01-31-2012, 01:37 PM
Default Pro-106 Programming Cable
looking to buy a Pro-106 to compliment my Pro-197. is the programming cable i have for the 197 the same one used for the 106?
'73
Rich, N9DKO
Old 01-31-2012, 01:41 PM
Wiki Admin Emeritus
Yep - it should work just fine Mike
Old 01-31-2012, 02:08 PM
great. thanks
'73
Rich, N9DKO
Old 01-31-2012, 10:30 PM
I use the same cable for my 106 and 197 and never had any problems
EMT
Old 02-03-2012, 07:25 PM
jassing's Avatar
Send a message via ICQ to jassing Send a message via AIM to jassing Send a message via MSN to jassing Send a message via Yahoo to jassing Send a message via Skype™ to jassing
When using the cable, do you use the "pig tail" adapter?
The paper work shows that the pigtail is used for base/mobile scanners, and directly for handheld...
The driver appears when I plug in the cable; but no software will read the scanner...
any idea what I'm doing wrong?
thanks
Old 02-03-2012, 07:33 PM
Wiki Admin Emeritus
I'm going from memory here, but I believe you don't use the pigtail...best regards..Mike
Old 02-03-2012, 07:43 PM
jassing's Avatar
Thanks Mike! I guess I was just worried about shorting something out--- that was it!
Old 02-03-2012, 08:29 PM
Send a message via AIM to 04Z1V6 Send a message via Yahoo to 04Z1V6
This is correct.
Pro-2096
Pro-106
(3)Pro-197
BCD396XT
Old 02-03-2012, 09:11 PM
correct. i don't use the pigtail for my 197 or 106.
'73
Rich, N9DKO
Old 02-08-2012, 09:59 AM
Default pro 106
i have a pro 106 and never downloaded no programe on it that 2.0 are whatever ones they have,what will my scanner do more if i download it will i be able to sepeate locals from state pol air med. any help thanls
Old 02-08-2012, 10:33 AM
Using WIN500 (Or any of the other programing software) makes it easier to manage the information in the different scanlists
Doug
Pro2B/40/43/77/83/84/89/96/97(2)/99/106/107/137/164(2)/2026
BC235 BC245 SC230 ICR3, ICR10
+ HF, VHF & UHF Xceivers from Alinco Icom Kenwood Yaesu Vertex Maxon Mot & RS
Old 02-08-2012, 10:39 AM
jassing's Avatar
I agree -- While I came from a scanner that you had no choice, you had to enter manually each frequency into each bank; I found the Pro197 about the same to manually program; but with better organizational powers.. (move from bank to bank, etc)
The cable makes it very nice (IF you have a windows system) -- and if you have a subscription to RR - it makes your life a LOT simplier/easier -- you'll spend more time listening.... I second win500. PSREdit was a very close 2nd choice.
Old 02-08-2012, 02:25 PM
HogDriver's Avatar
Just something to throw out there. If you have a 197 and a 106, you can program the 106 from the computer then patch the 106 to the 197 and clone it. It makes it easier if you have a radio mounted in your vehicle.
Old 02-08-2012, 02:28 PM
HogDriver's Avatar
BTW has anyone figured out how to print out your programming database from Win500 so one can have a hard-copy of what's in the radio? I have over 1600 objects in mine!
Old 02-10-2012, 02:47 PM
thanks
