Old 02-06-2012, 4:40 AM
Default APCO 25 phase II and PRO 197
Can someone help me understand exactly how phase II APCO 25 will be different from phase one, and will the 197 decode it?
EMT
Old 02-06-2012, 5:40 AM
W8RMH's Avatar
Project 25 Phases
Both formats are 4800 symbols per second - where each symbol encodes two bits of data for a raw bit rate of 9600 bps.
Project 25 Phase I FDMA
Phase I FDMA consists of a C4FM modulated signal that fits in a 12.5 kHz wide channel or a CQPSK modulated signal that fits in a 6.25 kHz channel. Motorola has established an additional de-facto standard for simulcast with a Phase I compatible variation called LSM. LSM is a CQPSK modulated 12.5 kHz wide signal.
Motorola X2-TDMA
Prior to the final Phase II standard being approved, Motorola developed and implemented their own TDMA protocol known as "X2-TDMA". X2-TDMA was implemented on the following systems:
Prince George's County MD Project 25 System
Loudoun County VA Project 25 System
Apopka County FL Project 25 System
Project 25 Phase II TDMA
The Phase II standard is a 2-slot TDMA signal that fits inside a 12.5 kHz wide channel. This allows existing 12.5 kHz wide license holders to double call capacity by upgrading their infrastructure to Phase II. The Phase II standard was approved in November 2010 [1], and as of August 2011 Motorola has begun shipping Phase II systems [2] [3].
These systems can operate in a mixed-mode configuration of Phase I FDMA and Phase II TDMA. If a Phase I only capable radio affiliates with a Phase II talkgroup, these systems are configured to automatically use Phase I modulation on the frequency.
Scanner Support for Motorola X2-TDMA and P25 Phase II TDMA
Motorola's X2-TDMA protocol can be decoded with the GRE PSR-800 EZ-Scan Digital Scanner. The PSR-800 is currently the only scanner model with the hardware to support any form of TDMA decoding (as of August 14th 2011).
On August 13th 2011, GRE stated that the PSR-800's support for P25 Phase II TDMA cannot be confirmed until it is tested live on a system that uses the final Phase II TDMA standard.
On December 18, 2011, a PSR-800 user confirmed that the PSR-800 cannot currently decode P25 Phase II TDMA (only X2-TDMA).
Uniden has confirmed that none of their current models support TDMA in any form, nor do they have the requisite hardware to do so, therefore cannot be made TDMA compatible via a firmware update. [4]
X2-TDMA can also be monitored with DSD.
Printed from: Project 25 - The RadioReference Wiki
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
Columbus Police Citywide Dispatch
Old 02-06-2012, 6:43 AM
Wiki Admin Emeritus
No, the 197 won't decode it - HOWEVER if the system you're listening to reverts to Phase 1 because other users are also Phase 1 on that talkgroup, you'd be able to hear it. That is the way of things that I've noticed on the PG county system (it doesn't happen all that often, frankly)
Old 02-07-2012, 12:40 AM
Thanks for the info. Is MOTOturbo also TDMA?
EMT
Old 02-07-2012, 1:23 AM
W8RMH's Avatar
Yes, Mototrbo is also TDMA.
Old 02-07-2012, 3:30 AM
Will RS possibly produce an APCO 25 II capable scanner in the future, and if so, will it also be capable of receiving MOTOturbo?
EMT
Old 02-07-2012, 3:57 AM
W8RMH's Avatar
It is possible. I think it has a lot to do with licensing and copyrights. Phase II was waiting on the final version. Mototrbo can be monitored with DSD
