Old 11-07-2005, 07:02 PM
mark125's Avatar
Default pro 96 frs/gmrs
I have a pro96and trying to scan the frs/gmrs channels.I dont pick up anything unless i manually pick the right channel.I wondered what i was doing wrong?
Old 11-07-2005, 07:11 PM
MacombMonitor's Avatar
If you're using Win96 software, you have to check the box that says; Search On [ ] for that group. Not sure how you do it from the scanner alone, maybe just pushing the Search button! It's the only pre-programmed band that's setup that way...not sure why either.
MacombMonitor
Old 11-07-2005, 07:30 PM
I set up bank -9- for surveillance. All Color dot VHF/UHF, then FRS/GMRS, DEA drug plane and others. I can e-mail my custom list if you like. larryscan@charter.net
Old 11-08-2005, 12:31 AM
it function and scan
Old 11-08-2005, 12:25 PM
To manually begin searching hit function, search. Do the same to stop.
Old 11-09-2005, 08:39 PM
mark125's Avatar
Thanks for the help .search then fuction worked.
