Got a pro-197! Was trying to update it, and add channels. I didn't download anything before I did it, so I don't have anything to backup to. Something happened in the middle of the update and now this is all it says on the screen.
up BootVer:RF 1.2
Up app Ver NONE
CPU SW Upgrade
Wait for PC /IF
Sometimes it will start updating the CPU but then the scanner will in just a matter of seconds say error turn off.
When trying to update the DSP the computer says it received an error message from the scanner. Please try again from step 1.
(also up at the top of the screen it literally says scanner version: ?:?)
I'm using the correct USB cord only, no adapter, it is on the correct COM, I even went in and changed the com # in device manager to make sure! I'm holding down program as I power on the scanner! Any other suggestions? Please help!
up BootVer:RF 1.2
Up app Ver NONE
CPU SW Upgrade
Wait for PC /IF
