Originally Posted by Onetechyguy
I have a question though about the signal stalker, when I press & hold the button it is searching the bands but not finding much at all, EX: like the police freq's I have programmed. Is that because I have to be close to the transmitter like a freq counter? If that is the case then ok. If it does stop on an active freq and I want it, how do I load it into memory?
Signal stalker operates similarly to a frequency counter I believe. It is basically for powerful signals nearby and can be compared to Uniden's Close Call if you know anything about it. Examples would be a portable radio down the street or something similar or a base a few hundred feet away. If you are searching for frequencies, you might want to consider using the
Search function and check out SR3 (Public Safety).
As for weather, can't provide much feedback as I don't have experience with the Pro-164. I did a quick check of the NWS page and it looks like there are quite a few different weather stations covering the area you live in. You may want to try hitting WX a second or third time to see if it improves at all.
If you haven't seen the
Easier to Read manual, try checking it out. It's usually pretty thorough and will most likely teach you a thing or two about your new scanner.
Easier to Read Pro-164/163 PSR300/C/400/C Scanner Manual
