Old 11-23-2012, 8:48 PM
Default PRO197 and Wildcard
I have scanlist #1 with a CC and Wildcard only, And used it to get VC and TGIDs. So that list had worked fine and I stop useing that list after I got all the VC and TGIDs.
So with the info I got from scanlist #1 I have scanlist #2 (pd) #3 (fire) #4 (multi) with the same CC and TGIDs for each scanlist with No wildcard and I have no problem.
I used scanlist #1 today and it will now only get the same two VC and that is it. So I have had it on allday and the log says only two VC for scanlist #1 but all VC are on scanlist #2,3,4
Has anyone come across this kind of problem?
Old 11-24-2012, 2:31 PM
Moderators please delete this thread, Problem solved..
Old 11-24-2012, 2:34 PM
mule1075's Avatar
Send a message via Yahoo to mule1075
What was the problem and how was it solved? It could help others who run into the same problem.
Uniden 200xlt/250d/8500xlt/780xlt/796d/996t/346xt/396xt/HP-1E
Radio Shack Pro-2006/160/197.AOR 8200MK3
My Scanner Feed http://washpascan.no-ip.biz:8001/
Old 11-24-2012, 7:56 PM
N1BHH's Avatar
Send a message via Yahoo to N1BHH Send a message via Skype™ to N1BHH
From the explanation, it doesn't sound like a problem, just that there isn't much activity.
WQLF416 = GMRS
Pro's 94, 106, 164, 197 (2), 2006, 2015, 2021, 2055
Old 11-25-2012, 12:23 PM
The problem was due to a programming software glitch and or operator error.
The custom bandplan table for that TSYS was partly incorrect for scanlist #1, So that explains why I was only to recive two VC.
I had examined the bandplan tables for all my TSYS and found that the table for scanlist #1 was the only one incorrect. So when I reentered the correct custom bandplan table I had notice that the incorrect table had now migrated to the next TSYS column down, Reentered the correct custom bandplan table for that TSYS and the incorrect table had now migrated to the next TSYS column down.
I had all of my TGIDs in numerical order and they all were scrambled, Scanner programming software glitch and or operator error.
All problems have been rectified.
Thanks.
