Old 11-28-2012, 6:02 PM
Default help pro 106
i have a pro 106 but need help to down load to it have no idea how to start got a 7 day trail to gre objest program cant make heads or tells all i need to do is download p25 freqs. plus need help to turn it on on scanner pls help
pro-95
pro-106
Old 11-28-2012, 6:08 PM
RonnieUSA's Avatar
You should ask for this to be moved to the Radio Shack forum.
You will get more help there.
Radio Shack Pro-197 - Uniden BCT15X
Win500 - ARC500 - FreeScan - ARC-XT-PRO - ID Tracker III
Old 11-29-2012, 4:09 AM
Wiki Admin Emeritus
Actually Ronnie you can request that yourself - click on the red and white triangle with the exclamation point in the upper right part of the message box (right above the join date), and fill in the form. I'll take care of this.
Spider, this article from our wiki (links are always blue) has numerous links to articles that will help. Some people find the Easier to Read manual to be a better read - click on that link in the first item under 'Onto the Real Question'
Getting Started with your GRE/RS Object Oriented Scanner - The RadioReference Wiki
There's also a link to the ARC500 user guide (which is, I believe, the software you got) in the Object Oriented Software article. In addition, in order to connect your PC and scanner, you will need to purchase a USB-serial converter. Take a look at the 'Connecting Scanners via USB' article for the 2 cables known to be compatible
HTH...Mike
Old 11-29-2012, 9:42 PM
WayneH's Avatar
Forums Manager
Moved to the RS forum.
-Wayne
PM's are disabled. Please use email through my profile or: wayne_h at radioreference dot com
Please do not reply to my moderator activity. I do not follow those threads.
