Old 12-04-2012, 12:26 PM
Angry Pro 2055 SQ problem
ok so i have in front of me a Pro 2055 that was mine - gave it to my sister its well cared for never been in a car out outside always used as base in a house
this is the problem the Sq seems to be "stuck" in the off poss .. i have tried everything resetting and initializing but still no go i cant get the SQ to turn up example i go to the WX channels it should scan though the channels to find location one but it doesnt
anyone heard of this anyone know to to fix ??
Brian
You can't stop the signal
http://www.mediafire.com/?sharekey=1...21d66e282a0ee8
Old 12-04-2012, 11:11 PM
gmclam's Avatar
Smile
Originally Posted by FCVPI99 View Post
Pro 2055 ... this is the problem the Sq seems to be "stuck" in the off poss
The purpose of the squelch is to mute (squelch) the audio when no (or too low) signal is present. A typical problem in that model of scanner is an open squelch potentiometer, but that is not the only thing which can cause what you describe. You could take the scanner to Radio Shack and they will give you a quote on repairing it, usually a flat rate. Otherwise someone would need to look at the signals and troubleshoot what is wrong.
PRO-95 | PRO-10 | PRO-97 | PRO-77 | PRO-92 | PSR-300 | PSR-310
Old 12-05-2012, 12:09 AM
thank you il have to find a radio shop around me somewhere LOL if there is such a thing
Brian
Old 12-05-2012, 7:19 AM
DickH's Avatar
Without a Service Manual or at least a schematic, a radio shop won't touch it. He said RADIO SHACK.
Dick H
http://dickh.zenfolio.com
Old 12-05-2012, 11:15 AM
thanks all guess il just pitch it .. there no way a radio shack tech is touching this GRE made radio
Brian
Old 12-05-2012, 3:26 PM
DickH's Avatar
PRO-xxx is considered a Radio Shack radio, regardless of who made it. They are the most likely to fix it.
Dick H
