Old 12-05-2012, 12:25 PM
Default Filtering Encrypted traffic
Is there such a way to filter encrypted traffic? We have one officer that likes to encrypt his traffic. We know who it is, but I would like to filter him (and others that do it) so it isn't so annoying.
Thanks,
Old 12-05-2012, 12:50 PM
Spitfire8520's Avatar
Looking at your posting history, it appears that you have a Pro-106. It does not have the feature to mute encrypted audio (there's a very limited exception to this). You would need a PSR-800 or BCD396XT/BCD996XT to have an ability to mute the audio.
Old 12-05-2012, 1:16 PM
Thank you.... I shall research and buy my next toy.
Old 12-05-2012, 2:16 PM
wtp wtp is offline
Default bcd396t
i have the old 396t and the next county has digital when they encrypt all i see for a second is ENC and it goes on its way
Old 12-05-2012, 5:16 PM
Could you not save the Radio's ID as a private talkgroup and then lock out that private talkgroup, thus causing the scanner to skip all transmission by his RID? I have never tried this. However, if you can alpha tag RIDs saved as private talkgroups, you should be able to lock them out also, correct? I will test this theory and get back to you with my results.
Nick, KF4SEK
RadioShack PRO-106, GRE PSR-310, Uniden BC346XT, ICOM ID-880H, ICOM IC-91AD, M/A-Com M-RK II Scan, Wouxun KG-UV3D, ICOM IC-80AD, Internet Labs DVDongle & DVAP Dongle, BAOFENG UV-5R
Old 12-05-2012, 7:01 PM
gewecke's Avatar
Thumbs up
Indeed, save the encrypted talkgroup as private, program in a list as private then lock it out. This DOES work with the pro-106 and 197.
73,
n9zas
Old 12-05-2012, 9:04 PM
I was thinking about this exact point as I was writing up my reply, but a quick search on the forums indicated that locking a certain RID out doesn't function that way. OP could definitely try it and report back to whether or not this idea would work.
73,
n9zas
I believe that OP is referring to a single user on the system who likes his encryption option a little more than the rest of his coworkers.
Old 12-05-2012, 9:12 PM
Correct... TGRP 2340 has about 20 PD officers in this small town, with ONE that likes to be annoying with his encryption.
I guess before I sell my pro-106.. is there a reason why I shouldn't sell it and get the BC radio?
Old 12-05-2012, 9:15 PM
asurnin's Avatar
I know my PRO106 misses radioIDs sometimes when it tunes into the talkgroup after the initial channel grant. So while that's about your only opinion, it may not always save you either.
Someone mentioned that there is an exception to 106 not muting enc. what is it?
Old 12-06-2012, 10:33 AM
Technical wise, a 3600 baud CC that has a specific packet of data that indicates whether or not the traffic is encrypted. That's about the only exception I've heard of, it won't mute encrypted conventional or new P25 systems. Someone should correct me if I'm completely wrong here.
The Pro-106 is a great radio in itself, it's just very unfortunate that a single Officer likes to mess with those who want to monitor. The BCD can monitor the same systems the Pro-106 can, and if money is an issue for you, you may want to consider holding off on buying a new scanner as technology could go anywhere in a few years. If your area were to unfortunately switch to a P25 Phase II system, then the BCD would become a brick as you won't be able to hear anyone at that point. You may want to poke around the Kansas forums to see if anyone knows of any plans to upgrade.
If you end up wanting to get rid of your Pro-106, consider trying the classifieds on these forums, that way the radio will find itself a good home.
Old 12-06-2012, 1:20 PM
Redneck0410's Avatar
Mark, if you're interested in selling it, hit me up, I'm looking for a digital to add to my collection. I've got a couple analog ones that would work pretty good for the Wichita system.
I DO support Broadcastify! My feed can be found at http://www.broadcastify.com/listen/feed/12468
Old 12-06-2012, 1:23 PM
gr8rcall's Avatar
In that case, I think you can get his RID, program it as a private ID, and Lock it Out. Right?
EDIT:
I see that this was already mentioned....
Supporter of Broadcastify!
Play "Travel Scrabble" here: Travel Scrabble (Word Game)
For ALL (not some) have sinned, and fall short of the glory of God! Romans 3:23
Don't be fooled, I'm not a LEO!
Old 12-07-2012, 2:41 PM
That technique of labeling the TG-private and L/O only works in "scanning" scanlists, when im sitting on a "Wildcard" on my RS106/197 i still receive all the "ENC" sounding TG's.....?
RoninJoliet
