Old 12-07-2012, 8:04 PM
FPOWLD's Avatar
Default Adjusting Antenna height
I have a Pro 197 and scan 800 digital frequencies and wonder with the included adjustable antenna should it be fully extended or lowered for the 800 digital frequencies. I know that with it fully lowered (like a rubber ducky) I can get my local tower (3 miles away) just fine but being 800 I was wondering if it made any difference for towers/ departments 10-15 miles away?
PRO96 , BC278CLT
PRO2037, PRO2053
Plectron Model 700
PRO197
Old 12-07-2012, 9:54 PM
Redneck0410's Avatar
If you can hit the control channel from your location, it shouldn't matter much, I don't think. If it's weak, try moving the antenna around or putting it on an external antenna if that's feasible for you. That might help you too.
I DO support Broadcastify! My feed can be found at http://www.broadcastify.com/listen/feed/12468
Old 12-07-2012, 10:33 PM
gewecke's Avatar
Thumbs up
To answer your question, push your telescopic antenna all the way in for 800 mhz. Shorter would work even better at that frequency range, which is why many users of the pro-197 collect various antennas for their favorite bands.
73,
n9zas
Old 12-07-2012, 10:52 PM
DickH's Avatar
These are the approximate lengths for the various frequencies:
800MHz - 3.25"
460MHz - 6"
154MHz - 18"
Dick H
http://dickh.zenfolio.com
Old 12-08-2012, 8:15 AM
Rt169Radio's Avatar
It is like this:
Low band freqs: tall antenna
Middle band freqs: middle height antenna
High band freqs: short antenna
Old 12-08-2012, 8:29 AM
FPOWLD's Avatar
Thanks for the info. I'll give it a try.
PRO96 , BC278CLT
PRO2037, PRO2053
Plectron Model 700
PRO197
Old 12-08-2012, 10:58 AM
I would try all different ways to see what is best for you, I know a friend and me found out that his 197 worked better with it one segment collapsed leaving 3 segments for 800mhz, just a thought
73,
n9zas
This is Correct
LOVE AND BLESSINGS
