At this point in time,no existing scanner will scan a MotoTRBO system directly. No ifs, ands, or buts. It can be done using external software as indicated above however and in that case since the software is doing the decoding practically any scanner that can be modified to add a discrimiator tap will work (even some very old and cheap analog-only scanners like the RS Pro-95). This setup won't be portable since you'll need both a scanner (to pick up the signal) and a computer (to do the decoding).
