| Radio Shack Scanners A forum for the discussion of all Radio Shack scanning radios and receivers. |
12-19-2012, 11:27 PM
Real simple..... You already got a radio that is programmed. You already I assume got software and cable. And you got a radio that is programmed already. Read that radio, save file, then put in new radio. Simple as 1,2,3. And there is something wrong with those TG's they were testing all day and nothing was heard.
12-19-2012, 11:34 PM
spitfire, thanks
basically you told me to check the db page 3 times and the info was there and I have said over and over that if the data was there i wouldnt need to post on here asking for help.
Bellarie isnt in the list so what is the solution?? I guess its my fault i didnt state in first post this was a rebanded ch. Tomball is 40 miles away, but you wouldnt know that. Everything listed is far away from Bellaire, which is in the center of HOuston.
So now what?? What city do you use that is no where near where I want? Obviously the cities are listed separate for a reason.
gjhamilton if i had a programmed radio I wouldnt have spent days asking for help
Yall are all too smart for your own good and dont see the trees for the forest. I do appreciate everyones help, seriously I do. Take a step back if you plan to help someone on here.
MODS CLOSE THIS THEAD
12-19-2012, 11:36 PM
I guess that I thought the picture of the radio with the right TG was one that was already programmed.
12-19-2012, 11:40 PM
Control Channels
026 (1A) 6900 North Gessner Harris 851.13750 851.46250 852.63750 852.91250 853.13750 853.63750 853.88750a
856.71250 859.21250c
TG
17008 427 A Bellaire PD Bellaire Police (primary operations on 460 MHz) Law Tac
12-19-2012, 11:54 PM
Tomball was ONLY AN EXAMPLE of what to look for. I provided a link to a map ( Site Map: Texas Wide Area Radio Network (TxWARN) Motorola Trunking System, Metro Houston area, Texas) that shows you what's closest (Texas Medical Center). This will be my final post, you have been provided plenty of links and this post has degraded quite a bit.
12-20-2012, 7:13 AM
Supposedly, they tested for a few and the radios didnt pick it up.
My guess of why it didn't work is because the transmitting radio was affiliated to a different site than what was programmed in the scanner
But that's just a guess and it assumes the scanner was programmed properly to start with.
BC-210XLT
"Wise men speak because they have something to say; Fools because they have to say something."
12-20-2012, 7:26 AM
Originally Posted by gjhamilton
Look, put the CC from N. Gessner tower in the radio. Then put your TG codes in. Hex are for Motorola Radios which you dont have. And you dont even have to use a rebanded table since all the N. Gessner CC's stayed the same.
Are you sure about Gessner? I would lean towards Med Center.
BC-210XLT
12-20-2012, 10:36 AM
That's what they said at advanced. They programmed a radio for them that way. And that's how they are selling them.y
12-20-2012, 10:51 AM
Ok, time will tell.
BC-210XLT
12-20-2012, 7:51 PM
Pluto I hope you have all your systems in there so you can now monitor and enjoy!!!!
Michael KD2CUD
Radio Shack Pro 197
Kenwood TH-F6A
12-20-2012, 11:15 PM
Seems like you are right about Med Center. Gessner works but not so good for some reason.
12-21-2012, 5:21 AM
I'm not as dumb as I look.
BC-210XLT
12-26-2012, 1:25 PM
