Old 12-31-2012, 8:56 PM
Default Bricked my Pro-107 trying firmware update...
I hope someone can help me here!
My Pro-107 has always had trouble listening to an EDACS ESK system not too far from me. My other scanners can hear it and decode it with no degradation of audio. The Pro-107 would sometimes not stop on a TG at all (the other scanner stops on it just fine) or it would stop, but would be staticy for a couple of seconds and then pick up the TG loud and clear (the signal strength meter would fluctuate then lock on full strength. I know it's not an antenna issue as all the radios are run through an active multiplexer and that is the only one that doesn't work properly). Frustrated in the quality of the 107, I thought maybe it was an issue with the firmware trying to decode the ESK format. So...I tried an update and got the following screen:
uP BootVer:RF1.1
up:App Ver: NONE
CPU SW Upgrade
Error - Turn off
The only way to turn it off is to remove the power cord, as pressing the power button doesn't register now.
I figured maybe the software was out of date so I updated that as well. Now the software will at least see the radio and try to update the firmware, but every time I try to load it to the radio it fails. The software gives me:
"The update of the firmware to the scanner failed. The scanner rejected the upgrade! This is usually due to a corrupt download from the Internet. Please try the update again."
I tried it several time....several times it failed.
Have I completely bricked my radio?
Any help is much appreciated!
-Travis
"The Nation which forgets it's defenders will itself be forgotten."
Old 12-31-2012, 9:42 PM
mikepdx's Avatar
Did you try a HARD reset?
In other words back to factory defaults,
then try upgrading??
All I can think of.
Good luck & Happy 2013
PS: Just found this. Look at this RR thread:
Bricked my Pro-107 Help!!!!!!!!
Read thru the whole thread.
Old 12-31-2012, 9:49 PM
I'm not sure how to try a hard reset. Hopefully that'll work!
I looked though the other thread and I tried everything in there and nothing worked. I'm at a loss..
-Travis
Old 12-31-2012, 9:57 PM
mikepdx's Avatar
did you read the posts from user 'Kingmobileaudio' in that thread?
He uploaded some iscan software for download and another user said
it fixed the issue.
If no go, you might PM him and see if he has any suggestions.
Old 12-31-2012, 10:24 PM
Red face Fixed it!!
FIXED! I'm beginning to HATE W7...nothing seems to run on it. I had to break out my old XP machine and load iScan on it and do the upgrade from a Windows XP computer.
Worked like a charm...
Thanks and Happy New Year!
-Travis
Old 01-01-2013, 1:53 AM
zzdiesel's Avatar
They way I understand it; our scanners are hard to brick. I've bricked my Samsung Galaxy Note cellphone twice in the last 3 weeks though. UGH!!!
GRE PSR-600, BCD996XT
Win500, Freescan, ID Tracker III
Old 01-01-2013, 10:33 PM
Wink
As a bonus, the firmware update corrected the trunking problem I had as well! I guess it just needed a kick in the pants. That's great, 'cause that saves me buying another radio...
-Travis
Old 01-12-2013, 3:22 PM
Try starting the software " RUN AS ADMINISTRATOR "
Old 01-12-2013, 4:25 PM
gr8rcall's Avatar
That has solved ALL my win7 problems!
Supporter of Broadcastify!
Play "Travel Scrabble" here: Travel Scrabble (Word Game)
For ALL (not some) have sinned, and fall short of the glory of God! Romans 3:23
Don't be fooled, I'm not a LEO!
