Old 01-08-2013, 8:17 PM
revclstoner's Avatar
Default Power Adapter for RadioShack Pro-2096
So my original adapter to my RadioShack Pro-2096 started to go bad on me. So I ordered a "after market" adapter online. I had the adapter for about 2 weeks. Now the "after market" adapter is going bad. I am now using my OEM adapter (I have to place the cable a certain way for the scanner to operate.).
Question: Where can I purchase a good quality adapter for the Pro-2096 without breaking the bank?
Note: Went to RadioShack last month and was told that they didn't sell any for that type of scanner. :-(
Cedric L. Stoner (Facebook/Twitter)
Monitoring: Southeast Texas Regional Radio System
RadioShack Pro-197 • RadioShack Pro-2096 • RadioShack Pro-106 • Uniden BC355C
Old 01-08-2013, 8:41 PM
KevinC's Avatar
Moderator
Are you sure it isn't the jack on the radio that's bad?
BC-210XLT
"Wise men speak because they have something to say; Fools because they have to say something."
Old 01-08-2013, 8:44 PM
How can I find out if the jack is bad?
Old 01-09-2013, 7:17 AM
KevinC's Avatar
Moderator
If you have a volt meter check the voltage of the adapter separately while twisting the plug. If you don't have a VM it will be pretty hard to test, but since you said moving the plug around fixes it, it's a good bet the jack is bad.
BC-210XLT
Old 01-09-2013, 8:06 AM
Hmm...I don't think I have a volt meter. Now on my OEM scanner, when I move the cable round near the plug itself it works.
Old 01-09-2013, 11:03 AM
lehigh4me's Avatar
Sounds to me more like you have a broken wire in the cable on the old one, if you can lay the cable a certain way and make it work. Do you do Ebay? Should be a adapters on there, or you can probably get a universal adjustable adapter at Radoshack or a big box store.
Old 01-09-2013, 11:39 AM
I went to RadioShack last month and was told that they didn't sell that type of adapter... So I just ordered one off of eBay.
Old 01-09-2013, 2:06 PM
KevinC's Avatar
Moderator
So, are both adapters acting the same way? As in if you move the plug around they start working? If so, the odds of both of them breaking in the exact same way seems unlikely, which is why I leaned toward the jack.
I would bet you move the radio around or plug and unplug often or the plug got hit at some point, which broke it from the circuit board.
But, I could be wrong.
BC-210XLT
Old 01-09-2013, 5:44 PM
I don't believe the jack off the scanner broke. The OEM adapter may have a wire that is cut on the inside. When I place it a certain way, the scanner will power up. The after market adapter just went out on me. It makes a "hissing" noise when I connect it to an outlet.
Old 01-09-2013, 6:08 PM
delete
Old 01-10-2013, 2:58 PM
KevinC's Avatar
Moderator
Ok, well I tried. I would still suggest trying to get the adapter checked before throwing more money in more adapters.
Do you plug/unplug the adapter from the scanner often? Also, does the scanner sit so the plug gets hit or pushed on?
BC-210XLT
Old 01-10-2013, 8:34 PM
I appreciate the help! I did unplug and plug the scanner often. I am in the process of purchasing a portable scanner.
Old 01-10-2013, 9:47 PM
KevinC's Avatar
Moderator
You could always invest in a volt meter and check the adapter yourself. A good way to start learning electronics!
BC-210XLT
