All channels locked
nodrama7758
TOPEKA, KS
I have been trying to download software to bring my scanner up to date. WHAT A NIGHTMARE. I live in Topeka Ks and have a Radio Shack 164 scanner. So I think I have really accomplished a Major Tornado, just because I was able to download what I needed?? Well now I have no access at all-Due to it is now locked up tighter than-NEVER MIND. I would appreciate any help. Thank You PEACE-JOY-HAPPINESS
GrumpyGuard
NEWBERG
You say you are trying to download software to bring your scanner up to date. Do you mean that you were updating the firmware on your scanner? If you were using your premium membership to down load radio frequencies from RR to your scanner what software are you using? Are you getting any error messages when you upload to your scanner? It sounds like your scanner does not have anything programmed into it. Add some frequencies manually and see if your scanner will scan. If it scans from what you have programmed manually then you are not uploading to your scanner from your computer.
