| Radio Shack Scanners A forum for the discussion of all Radio Shack scanning radios and receivers. |
01-18-2013, 12:17 AM
Pro 197 squelch issue on VHF Hi
For a while I have been having this small issue on my 197 that is driving me a little batty.
On VHF Hi Frequencies I have been noticing after a transmission (depends on signal strength) it sounds like the squelch will open and stay open for little over a second and has become rather annoying, the thing is on these freqs I have a PL tone set for RX. I've tried looking for a reverse tone burst setting in ARC500 but didn't see anything. Is there a solution to this problem are am I going to have to live with it?
PRO-197, XTS3000, Astro Saber HT1250, MT2000, HT1000, FT60R, VX8GR, UVD-1P(2/1.25), TM741, FT8800R, DR235T.
WQOK964
01-18-2013, 3:10 AM
This wouldn't be a frequency that You changed to NFM would it?
After My home town went NFM, I changed the transmission to NFM, and was that a mistake, it sounded like the squelch was stuck at the end of every transmission, so I changed it back to FM, and it fixed the problem.
Not sure if that is the problem your having.
Radio Shack Pro-197 - Uniden BCT15X
Win500 - ARC500 - FreeScan - ARC-XT-PRO - ID Tracker III
01-18-2013, 5:25 AM
Great info, thanks for posting! I had switched everything over to NFM and was having the same issue, except it was on the VHF low freqs that I receive. Your suggestion fixed it. Thanks again!
Pro-197 & PSREdit500 - Uniden BCT15X & FreeSCAN - Vertex FTL-2011 - Yaesu FT50R
01-18-2013, 5:35 AM
Your Welcome.
01-18-2013, 8:49 AM
I'll have to give that a try. Thanks
WQOK964
01-18-2013, 9:37 AM
My 197 has been doing the same thing, and set to NFM on vhf as well. Thanks for the tip!
We seem to learn new tricks all the time with these radios.
73,
n9zas
01-18-2013, 11:29 AM
73,
n9zas
Yes We do, glad I could be of help to everyone.
01-18-2013, 12:50 PM
That seemed to do the trick. Thanks Ronnie
WQOK964
01-18-2013, 1:03 PM
Your Welcome.
01-18-2013, 2:21 PM
I wonder if their are separate internal squelch adjustments for FM vs NFM like in the BC780XLT that need to be tweaked?
mods.dk -> UNIDEN - BC-780XLT
BC-210XLT
"Wise men speak because they have something to say; Fools because they have to say something."
01-18-2013, 4:16 PM
There might be. In the ARC software and in the Win500 software there are tuning parameters for the scanner.
WQOK964
01-18-2013, 7:33 PM
I think maybe part of the problem you are experiencing is that you may be in a high RF environment, although you may not realize it. I have to set some, not all, but some of my VHF objects with attenuator activated.
WQLF416 = GMRS
Pro's 94, 106, 164, 197 (2), 2006, 2015, 2021, 2055
01-18-2013, 8:12 PM
i'm having the same issue i will give that a try also
Radio Shack Pro-94,Pro-197,Pro-2018,Pro-2044 / Win500
Uniden BC355N / Regency ACT-R-106 / Antenna Craft ST-2
01-19-2013, 2:34 PM
I have a 780xlt also, thanks for the link!
73,
n9zas
