| Radio Shack Scanners A forum for the discussion of all Radio Shack scanning radios and receivers. |
01-20-2013, 8:11 AM
Pro 106 multiple control channels
Hi all
Seem to be having a problem-I want to input different control channels into different scan lists (in order to see which IDs are associated with each channel), but it seems that when I try to input a new talk group the scanner automatically uses one of my other main groups info (with 14 channels) and automatically edits...
Any ideas what I am doing wrong?
01-20-2013, 8:36 AM
Originally Posted by viperdog
Hi all
Are you scanning multiple systems?
01-20-2013, 9:00 AM
Cedric,
Yes I am.
01-20-2013, 12:57 PM
You cant put control channels into a scanlist. When you set up a system you can assign the talkgroups to different scanlists, but not control channels.
Pro-106 / Pro-197
01-20-2013, 1:37 PM
Can you give him an example??? I have tried and it's not working...just thought I would ask..
01-20-2013, 1:55 PM
True. If you have the software and a programming cable, it can be a lot easier to program your Pro-106.
01-20-2013, 2:42 PM
WIN500- Down load system---talkgroup----control channels----chose scan list--
let me know if this is wrong...I wanted to put up the page but will not load right
01-20-2013, 2:56 PM
ARC500
I use ARC500. Let me download WIN500. Give me a few minutes, please. :-)
01-20-2013, 3:09 PM
Download System (select closest site; control channels will be downloaded), then talkgroups, then select scan lists.
Refer to the example below.
01-20-2013, 3:23 PM
YES!!! you did it...great....J O B
01-20-2013, 3:29 PM
Why thank you!!!
01-21-2013, 1:51 AM
Cedric, all,
Thanks for input!!
Turns out it was my bad - I was not using "new" when inputting the new talk group, but "system" hence the overwrite..all sorted now.
01-21-2013, 8:44 AM
Cedric, all,
Thanks for input!!
Glad to be a help! I don't do too much programming by hand; that's why I use software. But you can create a new trunking system from the TGRP menu.
