Old 01-20-2013, 1:52 PM
Default Issue with Pro 106
I have a new Pro 106 it has the current software offered. My issue is that I get reception skip. When I am listening to my scanner at times my reception skips whereas my Pro 96 will stay on the chan until the transmission is finished. It is actually worse when I am driving around. A friend has the same radio and has same issues. I used the Win500 program and am listening to a P25 system for Baltimore City and Baltimore County. other agencies on a traditional 800 mhz seem to work ok. Thanks in advance
Old 01-20-2013, 2:05 PM
revclstoner's Avatar
Hmm. Did you update the firmware for the scanner?
Cedric L. Stoner (Facebook/Twitter)
Monitoring: Southeast Texas Regional Radio System
RadioShack Pro-197 • RadioShack Pro-2096 • RadioShack Pro-106 • Uniden BC355C
Old 01-20-2013, 2:35 PM
VE3JSO's Avatar
does any chan has the pri turned on?
- Jamie VE3JSO
Pro 90, Pro106, KENWOOD 450S, yeasu ft-60r
http://www.starrsoft.com/software/win500/
Old 01-20-2013, 4:00 PM
morrisr3nd's Avatar
Check and see if WX has a pri set. It will cut in every few seconds to check the primary frequency like animaljr47 just mentioned.
Call on his name "JESUS" and he will answer you.
Ronnie
