| Radio Shack Scanners A forum for the discussion of all Radio Shack scanning radios and receivers. |
01-21-2013, 2:29 PM
Possible to manually reband a PRO-164?
I got a 164 that needs to be rebanded, can't find anyone locally who can, and I sure as heck can't justify 39.99 for a piece of wire, PLUS like around 20 for the dang software which I'll use once in a blue moon. Is there a way to manually reband the scanner? Pressing F+Trunk button, then F+3 I can select ''MULTI-TABLE' for 800MHz Motorola ch plan. Then after doing that, rpessing F+2 gets me Three ranges to set, all of them being:
Custom range x/3
Base: 406.00000
Offset: 380
Step: 25.00 KHz
Is there a way to set that up to be a 'rebanded' system for Cabarrus county?
01-21-2013, 8:12 PM
You really should get the cable and the software, makes for quick and easy changes. But when you program a rebanded system you need to find out what table fits the system.
Easier to Read Pro-164/163 PSR300/C/400/C Scanner Manual
Determining Base/Step/Offset for VHF/UHF Motorola Systems - The RadioReference Wiki
The only magazine devoted ENTIRELY to scanning
I'm sure someone in your area can help you, you might want to ask in your state forum.
WQLF416 = GMRS
Pro's 94, 106, 164, 197 (2), 2006, 2015, 2021, 2055
01-21-2013, 8:16 PM
Oh I see, that's for a UHF system, bah... Well I really just cannot afford to buy that cable, not justified for hte price, nor is it feasible when I may be looking at a new HF rig or a expensive repair to one.
01-22-2013, 3:46 PM
You've got me wondering, did you look through all 3 of those links? You should probably find someone in your area to help you.
WQLF416 = GMRS
01-22-2013, 4:52 PM
I did, yeah. I can't set the base freq. and such on the scanner to an 800 range, that thing I mentioned earlier is for the UHF trunking systems only between 400 and 500 mhz. Yeah, guess I'll have to find someone then.
01-23-2013, 5:23 AM
... Is there a way to manually reband the scanner? ...
No. You have to use a program and a cable.
01-24-2013, 12:34 AM
PRO-164 / PSR-300
Custom range x/3
Base: 406.00000
Offset: 380
Step: 25.00 KHz
The commands you quoted are used to setup 800MHz trunking, and you need to setup 400MHz UHF trunking. This issue is a pet peeve of mine as well, as the firmware author should have included the ability to edit these settings w/o requiring software.
The USB cable is more than just wire because of the USB to COM converter chip/etc included. If your computer has an old-fashioned COM port, you can use the older COM version cable which can be found used much cheaper. Since there are 3 programs you can use to do the programming, and each comes with a 30 day free trial, you have "free" options there to do the update yourself.
I can't imagine there is not someone in your area who could do this for you however. If you can't find them on this site, perhaps another such as CL.
PRO-95 | PRO-10 | PRO-97 | PRO-77 | PRO-92 | PSR-300 | PSR-310
