Old 01-31-2013, 5:24 PM
Default Pro197 signal in fee zing weather
This is the 2nd time this happened
On digital scanning only
In same way on a freezing cold bad weather day reception not as good
My antenna is in a good spot in my attic new cable wire to discone antenna
Could weather have something to do with it
Old 01-31-2013, 7:04 PM
gewecke's Avatar
Thumbs up
Ice on their antennas won't do your listening any good.
73,
n9zas
Old 02-01-2013, 8:32 AM
Rt169Radio's Avatar
Does the cold temperature follow a warm day? If so temperature inversion might be the problem.
Old 02-01-2013, 8:46 AM
n8zcc's Avatar
Is it possible you are getting snow and/or ice buildup on the roof? This would cause a loss of signal strength.
73 de n8zcc
Bytes are cheap so drop those acronyms.
Old 02-01-2013, 7:14 PM
I bet that's it
It does now that I think about it it is when ice and snow is built
up on the roof
Old 02-02-2013, 8:33 AM
Rt169Radio's Avatar
I bet that's it
up on the roof
Thats odd, would that happen? I mean the ice and snow would have to be really thick to mess up signals.
Old 02-02-2013, 7:40 PM
Today clear. Signal and snow on roof Rt169radio sounds right thank you
Old 02-03-2013, 5:10 AM
n8zcc's Avatar
It also depends on the frequency and the signal level as well as the amount of build up. A longer wave length would have more success as would a strong signal at 800 MHz.
73 de n8zcc
Old 02-03-2013, 8:22 AM
Rt169Radio's Avatar
About the temperature inversion thing? Or the snow and ice thing? When a person is right you got to check what you were right about.
Old 02-06-2013, 11:37 PM
Are you well within range of the transmission source or somewhat borderline? If you're well within range then its something else, but I had my pro-197 and pro-2096 monitoring a Tower that my location is well beyond the footprint of, and the 197 kept missing about a third of the transmissions from that Tower. However my 2096 picked up all of them. I sold the 197.
Old 02-07-2013, 3:39 AM
n8zcc's Avatar
You had something else going on. A receiving radio can not cause propagation issues, that is, if you are out of the line of sight (frequency dependent) of the transmitter's antenna, no radio is going to reach up and grab a signal.
73 de n8zcc
Old 02-07-2013, 8:56 AM
Hi Robert...my 2096 literally grabs everything, even miles beyond the Tower footprint. The 197 was missing some of those transmissions, so it's clearly not as sensitive as the 2096. You can't argue with solid consistent results. Nice Christmas tree on your QRZ. Lord Bless.
