Old 01-31-2013, 7:55 PM
Tramagod's Avatar
Default Pro-106 Power
I've just recently picked up a used pro-106 and I've read posts about the inherent dangers of charging the batteries in the radio. Are there any similar issues with powering the radio with a power supply while running the radio? I really don't want to risk damaging the radio. Thanks in advance for guidance in this matter,
N5PMK, Randy
Old 01-31-2013, 11:36 PM
Ronaldski's Avatar
Batteries been hash-rehashed SO MANY times here use the search -
RadioReference.com - Scanner Frequencies and Radio Frequency Reference
latest one was two weeks ago RadioShack Pro-106 Power Options
Old 02-01-2013, 12:01 AM
Tramagod's Avatar
Not a battery question, it's about use of the power supply, and in the future, if you don't have sometrhing positive to add after reading the post, just move on and we'll all be thankful.
Old 02-01-2013, 12:05 AM
Ronaldski's Avatar
My bad your right I saw the "battery" mentioned and after seeing so many threads on batteries before, Im sorry didnt fully read it,
Old 02-01-2013, 12:47 AM
alwayslookin's Avatar
I have had many scanners mostly all handheld and the only problems I have had is the plug coming loose on the scanner itself no over heating or any other problems in that nature "knock on wood" hope this helps in any way.
Old 02-01-2013, 3:30 AM
n8zcc's Avatar
N5PMK, Randy
I have a PRO-106 at work I listen to all day every work day powered off of a 9 volt wall wart (Radio Shack). I have a set of rechargeables in the black battery holder. The bottom part of the radio gets just a little warm but that is it.
73 de n8zcc
Bytes are cheap so drop those acronyms.
Old 02-01-2013, 6:19 AM
morrisr3nd's Avatar
I use a RS wall wart while in the hotel and a car adapter from Walmart while traveling.
Call on his name "JESUS" and he will answer you.
Ronnie
Old 02-04-2013, 8:45 PM
Tramagod's Avatar
Thanks for all the input, it's been most helpful.
Old 02-04-2013, 8:49 PM
revclstoner's Avatar
Amen! But I don't see an issue with just using a power adapter instead of batteries.
Cedric L. Stoner (Facebook/Twitter)
Monitoring: Southeast Texas Regional Radio System
RadioShack Pro-197 • RadioShack Pro-2096 • RadioShack Pro-106 • Uniden BC355C
Old 02-06-2013, 9:03 AM
I have been using my scanner almost 24/7 using the ac power adapter and never had any problems with the power.
I have done this since day one of my scanner
BCD396T, PRO-2050, PRO-2053, PRO-97, PRO-94, PRO-83, PRO-106, and AOR AR8000
Software Scancat-lite Plus, Win-500, Arc500-Pro, and BCD396T Uniden Advanced Scanner Director
Old 02-09-2013, 5:55 PM
Is a 9volt 1.2 amp adapter to much power for the pro-106? Don't wanna take a chance and burn it up. Thanks.
Old 02-09-2013, 10:04 PM
No, the radio will only draw what it needs from the supply.
Doug
Pro2B/40/43/77/83/84/89/96/97(2)/99/106/107/137/164(2)/2026
BC235 BC245 SC230 ICR3, ICR10
+ HF, VHF & UHF Xceivers from Alinco Icom Kenwood Yaesu Vertex Maxon Mot & RS
Old 02-09-2013, 11:56 PM
Ok Thanks.
