Old 02-04-2013, 12:16 PM
Question pro 106 scanner problem
have a pro 106 hand held scanner. have had it a month, am now having a problem. when trying to key the programming buttons i get a HEAP ERROR 22DB1F : 22E2 and the scanner quits functioning as if it is turned off. i turn scanner off and turn on again and it scans. when i key the buttons on right side of scanner the error message comes on again. i cannot program the scanner.
Old 02-04-2013, 5:38 PM
trsundstrom's Avatar
Mentor
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 4.0.4; en-us; DROID BIONIC Build/6.7.2-223_DBN_M4-23) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Try a full reset per the manual. If it continues, I'd go back to the store. HTH.
Tom - W2XQ - w2xq.com
RS PRO-2041 & PRO-106
Old 02-04-2013, 6:22 PM
Ronaldski's Avatar
Heap errors are caused by programming errors. I had a fellow other day who tried his own programming, had a heap error, I programmed it, all is well!
See more people commenting on heap errors-
RadioReference.com - Scanner Frequencies and Radio Frequency Reference
GRE/RS Object Oriented Scanners FAQ - The RadioReference Wiki
Heap Messages
I am getting a Heap Error message. What is causing this? You have some TGRP objects that are not associated with any TSYS. Associate or delete these TGRP objects and reload.
This is also discussed in this GRE Knowledge Base article
I am getting a Heap Full message. How do I fix this? This can be caused by having duplicate TGRPs in a TSYS.
GRE FAQ - PSR-500/600 Heap Errors - Powered By Kayako SupportSuite
Old 02-05-2013, 2:58 PM
Before I would reset it or take it back, go up to the top right hand corner and do a search on the term "HEAP errors." You will find plenty of posts adddressing this problem and how to solve it.
Shadcall
Pro 106 Pro 163 Pro 164
