Old 02-12-2013, 11:43 AM
Default Pro 433
I know these are old but it's what I have to work with. My questions are
1. Can u program a trunking channel and no trunking channel onto the same bank?
2. How do u program the priority by hand?
3. Can this be rebranded?
Sent from my iPhone using tapatalk
Old 02-12-2013, 3:27 PM
W8RMH's Avatar
A lot of information and links here Uniden Pro-433 - The RadioReference Wiki
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
Columbus Police Citywide Dispatch
Old 02-13-2013, 6:02 AM
DickH's Avatar
3. Can this be rebranded? ...
1. YES
2. Read Page 16 in the manual.
3. The term is re B A N D ed. NO, it cannot be re-banded, BUT you will have limited success monitoring the Palmetto 800 system.
Greenville Simulcast (Site 35) will give you about 75% of the traffic.
Site 31 will give you about 50% of its traffic and Site 17 will give you 75-80% of its traffic.
The criteria is if a freq. has a 5 in the 4th decimal place (like 856.2625) the PRO-433 will be able to track it. If a freq. has a zero in the 4th decimal place your PRO-433 can not track it. If you do the math, you will come up with the theoretical percentages I gave you.
Dick H
http://dickh.zenfolio.com
Old 02-13-2013, 7:24 AM
DB Administrator
Send a message via Yahoo to brian
This is somewhat true. This calculation is based on the asssumption that all frequencies are used equally in the system. I have found this to not hold true on the Palmetto 800 system. Some frequencies are more favored as voice frequencies and others are less favored, particularly the alternate CCs. There seems to be a prioritization of which voice frequencies are used first, if available.
All that means is that it's less straightforward to try to calculate how much traffic you'll miss with a scanner that does not support rebanding. You're still going to miss traffic - and if you're trying to follow a conversation or activity, and you're only getting 2 out of 3 transmission or 3 out of 4 transmission (at best), I think you'll find that to be sub-optimal.
Old 02-13-2013, 7:44 AM
DickH's Avatar
I did not suggest he would be happy monitoring that system with the PRO-433, I just gave him the information.
Dick H
Old 02-13-2013, 8:24 AM
Default Pro 433
Thank you both. I am looking to upgrade. But funds are tight everywhere these days.
