As long as you have the control channels programmed into the first four channels of the bank and the bank set to MOT it should work fine since the system is analog. If you wish to upgrade I suggest the Pro-106. And be sure to purchase the programming cable and buy Win500 online. I don't know if or when your county will go to a P-25 system, but it's a good idea to be ready, if and/or when. There are also Uniden models that will do the same thing.
WQLF416 = GMRS
Pro's 94, 106, 164, 197 (2), 2006, 2015, 2021, 2055
