| Radio Shack Scanners A forum for the discussion of all Radio Shack scanning radios and receivers. |
02-20-2013, 10:02 PM
I am confused now, earlier I suddenly was picking up the city fine, had no clarity issues and could hear everything 100%. Now it's back to normal, choppy and what not, If I hit analyze I am getting a 99% signal that jumps down to 75%. Anyone know what could cause that?
02-21-2013, 7:35 AM
It's called "overloading", caused by nearby transmitters. If you look around you may see a cell phone antenna site - usually a large aluminum pole with many antennas on it. If your scanner has an Attenuator, that should help.
02-21-2013, 4:57 PM
In my area, we have 4 starcom towers in the area.
My pro-197, tries to pick up all four at once, and the signal is choppy. I was told, if I can get it to just to pick up one of the towers, instead of all four, the reception would be awesome.
But I have no idea how to do that, any ideas?
I think its the same issue your having: Pro-197 trying to pick up multiple towers at once and tries to decode them all at one time so it hurts the receptiion
02-21-2013, 5:02 PM
Drop some frequencies
Start by deleting the site frequencies that you don't want to listen to or put them under a separate scan list so you can turn them on and off at will. You might have to duplicate your talk groups though.
Although the scanner can only scan 1 frequency at a time so unless you have your site frequencies jumbled together instead of grouping site frequencies together you might have some difficulties.
Not a difficult task with the software.
I'm sure someone with more experience will chime in with MUCH BETTER advice.
Call on his name "JESUS" and he will answer you.
Ronnie
02-21-2013, 5:04 PM
Do you think thats might be the same issue as the OP?
Thanks for the info, much appreciated.
02-21-2013, 5:16 PM
02-21-2013, 10:15 PM
I do live less then a mile from a cellphone tower so that's a possibility. BUT, I don't have any issues receiving the County signal so I am kind of counting out that it's the cell tower interfering. I do have multi-site turned off under the system settings.
03-17-2013, 3:51 PM
Try the ATT button for the frequency(ies) you were expecting better reception on. I was ready to sell my 197 because I couldn't receive half of what I could hear on my old PRO-96. Found out that really strong transmission signal overpower and I hear nothing. Kicked in the Attenuation button and wow I could hear transmissions I had been missing.
03-17-2013, 8:21 PM
I have an old "very old" cell phone antenna with a mag mount atop a metal file cabinet and it improves the 800 mhz band greatly and does about the same as the pull up on VHF/UHF. This antenna came from the old bag phones days, may be hard to find now tho.
