Old 02-16-2013, 1:37 PM
Default Pro-2006 discriminator tap
Hello
I have a quick question about tapping the Pro-2006.
I have a 10k capacitor and a 10k resistor, Will this work fine or what do i need to change?
I am trying to follow these instructions but I am confused.
Discriminator Tap
Old 02-17-2013, 6:00 PM
Audiodave1's Avatar
10K capacitor?
Capacitors are specified in microfarads (uf)..check your value.
I use a 3K resistor from the discriminator pin, to a 1uf tantalum capacitor to the center lead of an RCA jack.
http://www.jameco.com/1/1/682-tm-1-c...uf-35v-10.html
This has worked for 10 years for many decoding programs based on these instructions (optimized to my needs) Pro 2006 Scanner
Dave
If bad sound were fatal Audio would be the leading cause of death!
Old 02-17-2013, 7:55 PM
Do you use this configuration for the PRO-2006 specifically or another radio?
Thanks for the help.
Old 02-17-2013, 11:37 PM
Audiodave1's Avatar
My 2006, 2026 and a BC895. Resistor values vary a little depending on output level but in general it works the same on all.
Old 02-20-2013, 3:06 PM
Did you use line-in or microphone input?
Old 02-20-2013, 10:39 PM
Audiodave1's Avatar
mic.
I use this program Martin Zuther K-Meter, free effect for metering and monitoring audio levels to set levels to about -10 on the meter.
Old 02-23-2013, 2:06 PM
I have a 3.3K resistor, is that close enough?.
Also do you use a external soundcard or the internal soundcard?
Old 02-24-2013, 11:43 AM
Audiodave1's Avatar
Close enough, I use the internal computer sound card. (laptop and tower)
