Old 03-02-2013, 5:14 PM
Default getting an error
when I go to turn on or off a bank of talk groups on my my RS -197 I get an error message that says:
Heap error
229F21 : 22A6
I turn the scanner off then back on and the bank I was turning off or on is what I wanted it to be.
This has just started in the last week. Any Idea's?
Old 03-02-2013, 5:35 PM
RonnieUSA's Avatar
Heap error
229F21 : 22A6
Heap Error Message: you have some TGRP objects that are not associated with any TSYS
Have a look at this, and see if it helps. >>> GRE/RS Object Oriented Scanners FAQ - The RadioReference Wiki
Radio Shack Pro-197 - Uniden BCT15X
Win500 - ARC500 - FreeScan - ARC-XT-PRO - ID Tracker III
Old 03-02-2013, 9:07 PM
A search in the "Radio Shack Scanners" forum for "Heap" will list several similar situations and ideas for solutions.
Maybe this one will help, though the code is not identical. Scroll down to read about TSYS without TGRP scenarios.
digital scanner error code
Hope this helps,
73 QDP
[106/2SRA]
Old 03-02-2013, 9:59 PM
Thanks to every one for there help.
Old 03-02-2013, 11:52 PM
RonnieUSA's Avatar
Hope this helps,
I think that's what I posted about.
I might be wrong though.
Old 03-02-2013, 11:58 PM
gmclam's Avatar
Smile
I've found it happens when there is a memory error, such as from a bad upload. I've re-uploaded from software to resolve the issue. It could also happen if you load from a different V scanner.
PRO-95 | PRO-10 | PRO-97 | PRO-77 | PRO-92 | PSR-300 | PSR-310
Old 03-03-2013, 10:17 AM
@RonnieUSA: You are right, we referenced the same problem-scenario. Even though I didn't directly quote your post (which I probably should have for clarity), I was agreeing with your conclusion while also trying to promote forum-specific searching for known issues, because I have found that, with the rich collection of knowledge in these forums, in many situations searching and finding answers can be quicker than posting and waiting for replies.
Thanks,
73 QDP
[106/2SRA]
