Old 03-08-2013, 7:11 PM
Default HELP Pro-97 not scanning ????
Anyone have a problem with a pro-97 stuck on a bank and wont scan. I have all banks activated and it will just sit and flash on bank one and do nothing. I know its not the software or program because I can load it on my other pro-97 and it works with no issues. I can manually put it on another bank and same thing just sits and flashes and will not pick-up anything or scan. It almost apears the scanner is frozen and yes I have tried the factory reset many time and same thing. Any help would be great. Thanks
Old 03-09-2013, 3:30 AM
Wonder if part of the keypad has gone bad - like the scan button. Or perhaps the MANual button is stuck..
Is there anything in here that might be related:
Pro - 97 apparent keypad problem
Old 03-09-2013, 7:23 AM
If you have reset the scanner.. there is Nothing in it now... need to program something in it
Old 03-09-2013, 10:16 AM
no its not the keypad because I can activate and deactivate banks no problem and I get the beep on all buttons. Thanks for the reply
Old 03-09-2013, 10:17 AM
Yes after I reset the scanner I put the program back on and still nothing.
Old 03-22-2013, 7:58 AM
Leo200's Avatar
Try this, press manual, turn squelch to silent, press scan. hope this helps..
