Old 03-09-2013, 3:46 AM
Unhappy I NEED HELP PRO 164
hi im not used to the new scanners and i don't know if im programming it right i need help please i use the software and i bought a subscription but my scanner is only picking up one channel so please help me
Old 03-09-2013, 5:04 AM
RonnieUSA's Avatar
It hard to help, You don't list what your trying to listen to, or where your from.
So more info is needed to be able to help You.
Radio Shack Pro-197 - Uniden BCT15X
Win500 - ARC500 - FreeScan - ARC-XT-PRO - ID Tracker III
Old 03-09-2013, 5:13 AM
sorry im trying to listen to police and fire and im from mesa, arizona and the county is maricopa im not used to the new scanners i have and old one i bought from craigs list fro like $20
Old 03-09-2013, 5:28 AM
RonnieUSA's Avatar
You would most likley get better help from here >> Arizona Radio Discussion Forum - The RadioReference.com Forums, because they know the systems better than I do.
The following link I will post are for the easier to rad manual, and the available software for your radio, all have a 30 day trial period.
Easier to Read Pro-164/163 PSR300/C/400/C Scanner Manual
GRE GRECOM RadioShack PSR300C PSR-300C PSR400C PSR-400C PSR-300 PSR-400 PSR300 PSR400 PRO-163 PRO163 PRO-164 PRO164 PSR 300 PSR400 PRO-97 PRO-2055 PRO97 PRO2055 Software
PSREdit300 - Configuration Editor for the PSR-300, PSR-400, PRO-163, PRO-164, PRO-97, PRO-2055 and MFJ-8322 Scanners
Old 03-09-2013, 5:45 AM
Thanks so much for your help and I wish I knew about the trial because I just payed $40 to R.R. for their subscription :-(
Old 03-09-2013, 6:02 AM
RonnieUSA's Avatar
RadioReference doesn't sell software, I don't think.
What is the name of it? ARC300
Old 03-09-2013, 6:13 AM
RonnieUSA's Avatar
Anything listed as Project 25 Phase I, or Phase II, Your scanner can't receive it because it's digital, now this system You can receive, Maricopa County, Motorola Type II SmartZone , just stay away from anything with a capital D in the Mode section, You can't listen to, your scanner can't decode it.
Old 03-09-2013, 11:30 AM
Angry
That sucks cause I just wasted a lot of $ on the radio reference software product key and subscription
Old 03-09-2013, 11:42 AM
Mesa and Gilbert are on the TOPAZ digital trunk system. The Pro-164 is an analog scanner and cannot receive them. You need to purchase a digital scanner like the Pro 106 or 197. In addition Phoenix and many surrounding cities are also digital and operate on the Maricopa RWC.
Greg Jolly
Scanner Master
Old 03-09-2013, 11:44 AM
Thank you for that info do u know if I can get my $ back for software I paid for
Old 03-09-2013, 12:05 PM
Not sure where you purchased the software but software purchases are usually non refundable. Check with the company you purchased the software from.
Greg Jolly
Scanner Master
Old 03-09-2013, 12:11 PM
It was thru radio referance
Old 03-09-2013, 1:03 PM
chandler's Avatar
Send a message via Skype™ to chandler
E-mail the owner blantonl RadioReference.com Member Profile
Old 03-09-2013, 1:04 PM
Ok I will for sure thanks a lot
Old 03-09-2013, 7:44 PM
He might be confusing his premium subscription with some sort of software program. Like Ronnie USA says I don't think Radio Reference (RR) sells any software program. What they do is make it possible to download the information in the database as long as you have a software program, programming cable and the premium subscription which is what the OP has.
Shadcall
Pro 106 Pro 163 Pro 164
Old 03-09-2013, 7:57 PM
Wiki Admin Emeritus
While RR doesn't sell software outright, they do have a little sponsorship of sorts going on - check the wiki in the Software section of...
Programming Your Radio Shack Scanner - The RadioReference Wiki
Right at the top of the section...and while it doesn't say it, much of that software will also work with the associated GRE models...Mike
Old 03-09-2013, 9:56 PM
The premium subscription you have purchased from RR does not get you a software application for controlling or programming your scanner.
What your RR premium membership does get you (among other things) is convenient download capability through various software applications.
With many of the "recent" scanners, several competing applications (like Win... or Arc... or Free... ) will allow you to control/program your scanner. With most of these applications you can use your RR log-in credentials to download the "frequencies" or "systems" you want directly from the RRDB into your scanner, without having to use the radio's little buttons to do all that programming.
This is where the premium subscription is most often useful because it saves a LOT of time and lets you download conveniently and relatively quickly when your system-of-interest is updated in the RRDB.
Hope this helps,
73 QDP
[106/2SRA]
