Go Back   The Forums > Scanners, Receivers and Related Equipment Forums > Radio Shack Scanners
Old 09-01-2013, 11:01 AM
Default Pro-433 finally bit the dust
My PC has been down for a couple of days so I haven't been able to stream until last night. Finally got the PC all set up again (PSU died so I pulled an old Gateway out of the office to use in its place until I can build something new) and got Windows installed, ready to install the streaming software when I try to test the scanner on this PC's audio card and I hear nothing. Not even a hiss. I turn the squelch down and nothing. I unplug the cable going into the PC and nothing from the internal speaker.
I did a little bit of digging around and one guy said to take it apart and make sure a wire isn't broken or pulled loose. I took it apart and all the wires seem fine but there's some things on the board that I'm worried about. Here's a pic of the board:
So now I have to find a new scanner. I'm really dreading shelling out all that cash for a new one but this one hasn't been the best scanner really. What's the most affordable option for streaming right now? Needs to be a digital scanner, preferably under $300.
Old 09-01-2013, 2:10 PM
Junior08's Avatar
I have a Radio Shack Pro 106 listed in the classified section if interested.
Website Moderator
All information here is Copyright 2012 by LLC and Lindsay C. Blanton III.Ad Management by RedTyger
Copyright 2015 by LLC Privacy Policy  |  Terms and Conditions
