Ok I have a Pro 96 scanner. I am trying to find out how to do the rebanding. Is this completed with the radio shacks latest upgrade utility on there web site? Or is there something else I need to do. Where can I find out what areas have been rebanded so I can decide when I want to reband?
Also I have the squelch and volume control issue. This did not start until after it was out of warranty. I did make a temp fix by making a rubber spacer that applies a little pressure on the circuit board and it eliminates the problem. I would like to fix the issue correctly. Dose anyone knows what is causing it? Is there a bad connector or solder joint on the board? For the life of me I have not been able to find it.
Any info would be appreciated. I have searched the site and can’t find the info I am looking for.
