- Joined
- Feb 2, 2013
- Messages
- 26
Hello Everybody, I have a question about the blue EL Backlight.
Lately I have been having trouble with my backlight being dim, so I tried replacing it, but after that did not fix it I was stumped.
So later I checked the voltage.
The service manual states the output is 70 VAC 450Hz.
Mine is outputting 61 VAC, I did not check the frequency.
So have any of ya had this problem?
My best guess is bad power supply capacitors or a bad voltage regulator.
Otherwise the radio works fine just a dim backlight.
Also I have looked into using LEDs, Do any of you have tips on this mod, I have seen the mod with the Digi-key LED panel, I would rather the entire display be backlit and look like the original one.
Any help appreciated.
