Old 01-13-2014, 12:19 PM
scannerface27's Avatar
Smile pro-95 ?
I have a pro-95 and have had to send it in before for help through radio shack. I am having a problem with it picking up any of the Trunked systems in my area. The regular fm frequencies will pick up fine along with the wx channel. Mode is set correctly to mo mode but still nothing,even with squelch low still wont hit. Any suggestions before I send back to radio shack? Last time I sent it in they had to replace some kind of little electrical thing
2-pro-92's-bcd396xt-pro-163-bc200xlt..pro-95,
c.j.u.h.s.d. school officer."10-6 ALL DAY"
scannerface 27-feed prov-system 1-sbso
Old 01-13-2014, 1:12 PM
mikepdx's Avatar
Has that Motorola system rebanded since
the last time your scanner received the system well?
If it has rebanded, you are out of luck.
The Pro-95 can not be rebanded.
That could be it.
"I prefer dangerous freedom to peaceful slavery."
-- Thomas Jefferson
Old 01-13-2014, 1:17 PM
N8IAA's Avatar
Your county system has rebanded. The Pro-95 will not receive the frequencies in your area, especially the Apple Valley towers. This could be why you won't get your local stuff.
I'm sure someone from CA will chime in and let you know what you can hear beside the conventional frequencies.
HTH,
Larry
Digital/Analog scanning and hamming
Old 01-13-2014, 3:00 PM
Cool Pro-95
Thank you for your input and your attempt to help,
My friend Ernie has the same model and he hears everything thing that is transmitted, he listened to it last night and his works fine.
There hasn't been any re-banding, the reason I say that is because my pro-92, receives radio traffic with no problems.
I think there is something else that is causing my scanner to not receive the control channels still open or any other suggestions.
Old 01-13-2014, 3:40 PM
KevinC's Avatar
Moderator
Do you have it setup as a "Splinter" system?
BC-210XLT
"Wise men speak because they have something to say; Fools because they have to say something."
Old 01-13-2014, 3:43 PM
KevinC's Avatar
Moderator
HTH,
Larry
Are you positive San Bernardino County has rebanded? It's a "border" system so it has it's own set of rules for rebanding.
BC-210XLT
Old 01-13-2014, 10:14 PM
N8IAA's Avatar
If you look at the tower in Apple Valley, the CC's and voice frequencies have the dreaded '0' in the fourth place. His friend may have another tower programmed in. Don't know.
Larry
Old 01-14-2014, 5:34 AM
KevinC's Avatar
Moderator
Larry
That's because it's a "splinter" or "Border Offset" system. All of it's frequencies between 851-866 have always had the zero in the 4th place.
BC-210XLT
Old 01-14-2014, 11:00 AM
Red face
Yes kevin this is true I do have it set to splinter also. Last night pulled out the 92 and it worked well. I believe that the 95 has some other issue going on, im going to send it in to rs
Old 01-14-2014, 11:41 AM
KevinC's Avatar
Moderator
Well then, that's one thing that isn't causing your issue.
BC-210XLT
