  #201 (permalink)
Old 03-13-2014, 11:36 AM
mule1075's Avatar
Mine did it was taped to the lid of the box for some reason.
Sent from my Z750C using Tapatalk
Uniden BCD536HPx2/250D Motorola HT1000/GM360
  #202 (permalink)
Old 03-13-2014, 6:28 PM
zzdiesel's Avatar
Originally Posted by jyams View Post
Did your overstock scanners come with beltclips? I'm missing them on my shipment.
The one I bought has everything except the antenna.
Whistler - TRX-1 /w EZ-Scan
  #203 (permalink)
Old 03-13-2014, 7:37 PM
Smile
I guess I got lucky, mine came with software,cable, beltclip and antenna. Was not worried about antenna though as I went last weekend and bought another RS800 for it.This is night 2 with it and I do believe the reception is much better than my Pro106. The SCHP on the Greenville tower has always had a static problem,it is mentioned in the SC forums but with this little gem 95 percent of the static is gone. I just wish it had more buttons,but I am getting used to the menus. Super easy to program with I-Scan also.Just wish it was better on airbands.
I think I have it all now, from low to high,Icom R75,BCT15,Pro 18,Pro197, Pro106, 12 foot Unimesh C-band dish, 6 foot Ku band dish. Now if only I had the time to use them all!
  #204 (permalink)
Old 03-14-2014, 12:13 AM
Default pro 18
Any one no where to get the best buy on a ,,,usb ac/dc ,power adapter for the pro 18
  #205 (permalink)
Old 03-14-2014, 12:56 AM
man i just missed it
  #206 (permalink)
Old 03-14-2014, 5:50 AM
Dollar General usually has them for about $7.00 each for a ac to usb or car lighter to usb.
  #207 (permalink)
Old 03-14-2014, 8:58 AM
NWI_Scanner_Guy's Avatar
Question for those who have purchased this scanner....
Does the PRO-18 have the same 'hard to view display unless the back light is' on issue that the PSR-800 has? Would like to add one to the stable if they become available at this price again, but really don't need another radio that makes it hard to see what it's receiving unless the back light is on all the time.
Thanks for any information.
BCT15X / PRO-2051 / BC-355C
BCD436HP / BC-246T / BC-125AT
Alinco DR-605 / UV-5x3 / UV-82HP / UV-3R+ / JT-UV71
  #208 (permalink)
Old 03-14-2014, 9:54 AM
jyams's Avatar
The Pro-18 is the PSR-800 with fewer features as identified in the wiki, the most glaring of which is NO APCO P25 Phase II TDMA and X2-TDMA reception. The Pro-18 DOES have the same display technology as the PSR-800. I have both models and they are the same display. I program my display to come on for 10 seconds for each transmission. Yes, this does consume more battery, however, that's not an issue for me. I run mine mostly on the usb power port. Hope this helps your evaluation of the Pro-18. I have several Pro-18s and find them to be a very good scanner for my scanning needs. I'm keeping my PSR-800 for a Phase II TDMA system being upgraded this year in my local area.
KI4NQP
BCD536HD-DMR upgrade / Home Patrol-1 Extreme / Pro-18 converted to WS1080 / Pro-107 / Sony ICF-2010 / Hallicrafters S-38 / Degen DE1103 / ATS909 Super / Antennacraft ST2 - 30ft high
  #209 (permalink)
Old 03-14-2014, 8:12 PM
Default Pro 18 vs Pro106
Here is my take after sitting down with both side by side. I love my 106, but hands down th 18 has a better front end. My 106 missed some transmissions that the 18 got, but the main thing is the 18 is much clearer.The 106 has the advantage of pushing a button to add or exit playlists were you have to make a few button pushes to do it in the 18. Both are easy to program with software so it is a tie there. The 18 seems a little more battery hungry also. After trying this little jewel, I see a psr800 in my future. Just for a note I have a RS 800 duckie on both radios. Also the 18 has easier charging and powering options that are also cheap.
  #210 (permalink)
Old 03-15-2014, 7:53 AM
fredva's Avatar
A good summary. Although I would point out a difference in the software - the PRO-18 software is free, whereas the use of the PRO-106 software beyond the trial period requires a purchase.
PRO-18 upgraded to a WS-1080, PRO-197, PRO-2020, PRO-2021, 436HP, Raspberry Pi SDR
Fire & EMS feeds: http://www.broadcastify.com/listen/feed/527 & http://www.broadcastify.com/listen/feed/3331
  #211 (permalink)
Old 03-15-2014, 9:52 AM
rocksteady's Avatar
Let's remember that the updates are free and doesn't cost every six months just to update the database. A bonus for cheapskates like me.
Sent from my tricked out Droid4!
Some friends and family are like a slinky, they don't serve much of a purpose, but they sure are fun to watch when you push them down the stairs.
  #212 (permalink)
Old 03-15-2014, 11:51 AM
LIScanner101's Avatar
Last week when I clicked on the link provided on this thread it would pop up pretty quickly and say the item was out of stock. Today when I tried it went to the website but I get this circling set of black dots, as if it's searching or loading the page. Unfortunately it never stops - just keeps doing that until I exit the page. This is from a Samsung Galaxy III smartphone. Anyone else see this happening?
Base/Mobile Scanners: Uniden BCD996XT, Radio Shack PRO-163
Attic Antennas: Monitenna 5094A, A/S MONR31, MON-58
Mobile Antennas: A/S MONR33, MON-52
  #213 (permalink)
Old 03-15-2014, 12:02 PM
Default Re: Pro_18 Back on Overstock for $79...Hurry!
Was able to connect with my Samsung Galaxy Express. It's still out of stock.
Sent from my SAMSUNG-SGH-I437P using Tapatalk
  #214 (permalink)
Old 03-15-2014, 1:04 PM
Has been my homepage for 3 weeks or more now and constantly checking... have not seen it available at all
  #215 (permalink)
Old 03-16-2014, 3:07 PM
DJ11DLN's Avatar
Have been watching it closely too...mine was stolen. It was recovered, still works fine but it got nicely scratched up in the process. I'd love to have a second one anyway just to save the wear-and-tear on the BNC connector from transferring it between my house and car. Have had excellent performance out of this one, they seem to be really great scanners, just not quite up to PSR-800 capabilities. At this price they don't have to be; even for the $200 I paid for mine last summer it was a great purchase. I missed the first two lots, but I can't imagine they'd leave the page up unless they're going to get at least a few more. Good luck to all of us.
If it looks stupid but it works...it ain't stupid.
  #216 (permalink)
Old 03-20-2014, 10:45 AM
Paco-Jerte's Avatar
Last night around 2am local I checked and there was 2 available. Tried to check out but by the time I tried to pay they were gone. :rolleyes:
Sent from my SPH-L900 using Tapatalk 2
tons of scanners why list them huh
  #217 (permalink)
Old 03-20-2014, 10:53 AM
jyams's Avatar
That's amazing. I guess these Pro-18's trickle in from store returns and demo units. It's been unavailable at stores for like over a year, right? I keep seeing some ebay professionals selling these in multiple lots. Very interesting!
KI4NQP
  #218 (permalink)
Old 03-20-2014, 11:09 AM
got mine this morning... I am NOT happy...
no antenna... old style rayovac rechargables (the all purple ones) no cable. batteries had leaked in the battery compartment...
works but no cd
natures alcohol and a few qtips clean battery connectors up nicely...
new batteries and a spare diamond rh77ca oh and the tip of previous antenna had to be taken out of center of bnc adapter
thanks to for my local dollar store for having a usb cable to fit it...
and did I mention scratched?????
this went through overstock.com's inspection and quality control measures...
  #219 (permalink)
Old 03-20-2014, 11:10 AM
Same exact thing happened to me
  #220 (permalink)
Old 03-20-2014, 11:16 AM
works but no cd
You get what you pay for............. Sorry for the bad luck
Tags
pro-18
