Old 04-03-2014, 8:46 AM
Default Pro-2096 Scanner Re Banding
Can anyone tell me if the Pro-2096 Base Digital Scanner can be rebanded for the 700mhz band? My province is switching from 800mhz to 700mhz trunked radio system. Will I need a new scanner?
Old 04-03-2014, 9:42 AM
tonyclark's Avatar
No doesn't cover 700mhz band
Frequency (MHz) Step Size Value
25-54 5 kHz
108-136.9875 12.5 kHz
137-174 5, 6.25, or 7.5 kHz
216.0025-221.9975 5 kHz
222.000-225.000 5 kHz
406-512 6.25 kHz
806-823.9875 6.25 kHz
849-868.9875 6.25 kHz
894-960 6.25 kHz
1240-1300 6.25 kHz
Sent from my emachine using Tap-dat-key Pro
Old 04-04-2014, 5:42 PM
It won't trunk-track a 700 mhz system. However, I have read that if you program it with Win96, you can monitor 700 mhz frequencies in conventional mode.
RS PRO-18, RS PRO-197, RS PRO-2052
Fire & EMS feeds: http://www.broadcastify.com/listen/feed/527 & http://www.broadcastify.com/listen/feed/3331
Old 04-04-2014, 8:33 PM
Wiki Admin Emeritus
Keep in mind that the sensitivity might vary wildely on 700 Mhz from one unit to the next. One unit might work fine - another might be as deaf as a stone. This radio was never intended to cover this band, so it's really not so surprising.
And please, keep in mind that rebanding has absolutely nothing to do with 700 Mhz. It's another myth that keeps on rearing its ugly head from time to time.
