Is The Pro-405 Narrowband Capable As Advertised?
haleve
Banned
Pompano FL & Melville NY
If the information about being able to receive 7.5 kHz VHF high band frequencies & 12.5 kHz UHF frequencies is correct as advertised in the radio model section of the Wiki I should be able to program 155.7 MHz, 453.425 MHz & 463.1125 MHz or am I mistaken about this scanner being able to receive the new narrowband compliant transmissions? My present scanners, a UBC9000XLT, a BCT-8 & a BC92XLT are receiving these frequencies however the audio has now become lower in volume & very scratchy.
gh6406
Dalton,Ga
Narrow Band Capable
I don't think so, per the manual:
Frequency Coverage
29-54 MHz.......................................................................................(5 kHz steps)/FM
87.3-107.9 MHz .......................................................................(100 kHz steps)/WFM
108-136.99166 MHz...................................................................(8.33 kHz steps)/AM
137-143.9875 MHz.....................................................................(12.5 kHz steps)/FM
144-148 MHz...................................................................................(5 kHz steps)/FM
148.0125-150.7875 MHz............................................................(12.5 kHz steps)/FM
150.8-161.995 MHz.........................................................................(5 kHz steps)/FM
162-174 MHz..............................................................................(12.5 kHz steps)/FM
380-512 MHz..............................................................................(12.5 kHz steps)/FM
