Old 06-14-2014, 9:53 PM
Default removing limit search from pro106
I created a (limit seach 460-467mhz) for temporary use but when in scan it's always there along with the normal channel banks. I can turn on and off the other programmed banks 1-9 but don't know how to get rid of the (limit search). I don't have software and do all programming manually.
Old 06-14-2014, 10:10 PM
which ever bank you have the limit search programed to, go to that bank & hit edit , current , and push F3 for default, then save. that should get rid of the ones you don't want.
Old 06-14-2014, 10:15 PM
N1BHH's Avatar
There are no banks, this is object oriented scanning with scan lists. You have the limit search set up as an object. Simply Lock it out. Find it and Lock it out of whatever scan list it is set to.
Easier to Read Pro-106/197/PSR500/600 Digital Scanner Manual
WQWJ272 = GMRS
Pro's 94, 106 x2, 164, 197 x2 , 2006, 2015, 2021, 2055
Old 06-14-2014, 10:25 PM
Sounds like you programmed the limit search as an object. You will have to find it and delete it or lock it out.
If you setup a dedicated limit search, it will remember the last programmed Hi and Lo frequencies.
WS1098, 996P2, 325P2, 536HP, 436HP, PSR800, PSR310, Pro-106, Pro-97, BR330T, and wishing for a real base (not mobile) trunking scanner.
Old 06-15-2014, 10:23 AM
the search is scan list 20 hit function 0 To turn it on & off.
