Old 06-17-2014, 6:02 PM
Default Pro 197 - Can the LED light up for scan lists?
I would like to program each scan list to light up it's own color when any object within it is active. For instance I currently have all my local town emergency services under scan list #1 and it would be very handy to have that list light up as red. Then list #2 green, list #3 white, and so on.
I already know how to do this for individual objects, but I have looked and looked on the global settings with no clue how to do it for an entire scan list.
Old 06-17-2014, 6:50 PM
Default More Info -- Please..
Are you referring to each bank..?
Ryan S. Olsen
Old 06-17-2014, 7:33 PM
TES's Avatar
TES TES is offline
No banks on the Pro-197.
Old 06-17-2014, 7:44 PM
kc4jgc's Avatar
I haven't seen such an option.
Unless someone can prove otherwise, no.
Steve KC4JGC
I believe the Redskins name deserves to stay. It epitomizes all the noble qualities we admire about Native Americans—Honor. Loyalty. Unity. Respect. Courage. And more.
N1BHH's Avatar
The LED can be assigned to individual objects. If you are using software to program such as Win500, it's easy to do, assign a color, set it to flash, save the file and upload to the radio.
WQWJ272 = GMRS
Pro's 94, 106 x2, 164, 197 x2 , 2006, 2015, 2021, 2055
Old 06-17-2014, 7:47 PM
You would probably be able to do this by assignig the same color LED to every object in each scan list.. For instance, all objects in scan list 1 are set to RED. all objects in scan list 2 are set to BLUE and so forth
Old 06-17-2014, 7:50 PM
That is just what I was going to suggest. That's the only way I've seen it done.
Ryan S. Olsen
Old 06-17-2014, 8:57 PM
Yup, that's exactly what I had in mind too. I had just really hoped there would have been a slicker way to do it. With the amazing amount of options this unit has you'd think being able to color code each scan list globally would have been a given. Oh well, it's all good.
Thanks for everyone's replies!!!
Old 06-17-2014, 9:22 PM
Since the scanner will allow an object to be assigned to multiple scan lists, and since an object can have only one LED color (regardless of which scan list is active at the moment), the above idea will work only when each object is assigned to one and only one scan list. And the above suggestion seems to be the only way to achieve the OPs goal.
Hope this helps,
73 QDP
Old 06-18-2014, 8:10 AM
Meant to ask, are you programming these features by hand or with software on the computer? If on the computer, that "IS" the "Slick" way to do it.
Old 06-18-2014, 9:16 AM
An option would be to select LED color based on TG's function, e.g., police: blue; fire: red; public works: green;, etc.
Amp
Old 06-18-2014, 3:36 PM
I have the software that came with the scanner, but I already ran out the free trial time (downloaded it and then didn't even get to use it). I just don't use the software enough to justify buying it. I may try it someday once I get better at running this thing manually first and also find more frequencies to enter.
