Old 07-30-2014, 10:49 PM
Default Pro 164 Not Charging
My Pro 164 is not charging. When I plug it up to charge it simply shuts off. Anyone have this problem?
Old 07-31-2014, 4:29 AM
krokus's Avatar
Are you certain the power supply you are plugging in is working?
Sent via Tapatalk
Old 07-31-2014, 2:36 PM
gmclam's Avatar
Lightbulb
Definitely sounds like a bad (or unpowered) external power adapter to me too.
PRO-95 | PRO-10 | PRO-97 | PRO-77 | PRO-92 | PSR-300 | PSR-310
Old 08-01-2014, 8:28 AM
buddrousa's Avatar
Just a thought but do you have your batteries in the yellow battery holder and is your wall transformer rated at 9 volts dc at 1000 mil (1 amp) or higher. New batteries if not you may have a shorted battery.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 NX5200 Buddy
Old 08-01-2014, 10:18 AM
Wink PRO-164 not charging
I have found that if you have one of those chargers that the tips change so you can charge different thing, the tip might need turned around. You can try this if this does not work than you have a bad charger.
