I need to know;
1. If either TP4 or IC4 pin9 should be used for discriminator tap or a different one.
2. How many resistors and size uF and volt.
3. Is a capacitor necessary? Size?
Doesn't seem to be much info on this model for mods.
I'm posting a pic showing what I think the configuration should be.
I will be using a shielded wire and a 3.5mm mono jack.
Someone please let me know if the configuration is correct. Thanks
