On your last question - nope. Win500 and PSREdit500 should also work Mike
Ok but I found this on butel.nl
New Radioshack PRO-649 / PRO-650 / PRO-651 and PRO-652 software compatibility:
All versions of the ARC404 and ARC500 software packages are compatible with the new Radioshack scanner models that were released spring 2014.
Please refer to this table:
ARC404 is compatible with the PRO-649, PRO-650, PRO-404 and PRO-405 and the GRE PSR100 and PSR200.
***ARC500 is compatible with the PRO-651, PRO-652, PRO-106, PRO-197, GRE PSR500, GRE PSR600, Whistler 1040 and Whistler 1060 digital scanners.****
The free demo software that is included with the Radioshack 20-549 USB programming cable is also fully compatible with the new scanners.
Please refer to this table to select the correct software:
For the PRO-649 select the PRO-404 / ARC404 software
For the PRO-650 select the PRO-405 / ARC404 software
**For the PRO-651 select the PRO-106 / ARC500 software**
For the PRO-652 select the PRO-197 / ARC500 software
I used to use the win software, then started using Arc software and liked it much better.
